Old 7-15-08, 18:15   #181 (permalink)
  Total: 252 Power: 4
lundgren420's Avatar
Not a bad setup. I dont think the height would clear though.
1989 Probe GT M/T -my new toy
Old 7-16-08, 3:38   #182 (permalink)
  Total: 1192 Power: 5
fredio54's Avatar
That's an HX52W which is substantially larger than yours/mine ;-) It's under a civic bonnet which can't have much/any more space. Or do you mean where the bottom ends up relative to the road?
Typically the head is wider than the middle of the block anyway, so low mounting is a better option in many cases. It also means shorter smother ex flow which is one major reason i went low down even though I had less space down there.
Fred.
Old 7-17-08, 10:27   #183 (permalink)
  Total: 113 Power: 5
good work!
"Lack of pu ssy makes you brave man!!"
"Cocaine is a hell of a drug!!"
"What the fu*k is GOONY GU GU??"
"Mm mm mmm, that IS a tasty burger !! "
Boosting6 is offline   Reply With Quote
Old 7-27-08, 1:55   #184 (permalink)
  Total: 57 Power: 5
I just read through your build and checked out the pictures, great build! Good to see a fairly sized turbo on an FE3. My car looks just like yours, Red 89 PGT. Keep up the good work
-89 PGT- Stock Turbo
-03 Civic EX - The DD
discretelyelite is offline   Reply With Quote
Old 7-27-08, 2:07   #185 (permalink)
  Total: 621 Power: 5
NSXR's Avatar
Hey Man,
I just saw the pics you posted.
It is great to see the final product of your evil plans
I will be contacting you soon regarding the F8 internals.
@discrete: What finally happened with your FE-DOHC?
Peace
NSXR
Car #1: '91 626 2.2i 12V TURBO 4WD Hatch (Blown tranny )... Car #2: '91 626 2.0i 16V 4WS Cpe (Blown Headgasket)
NSXR is offline   Reply With Quote
Old 7-27-08, 2:12   #186 (permalink)
  Total: 252 Power: 4
Thansks man, just figured i could give you thoes paes for a lot cheaper to. Dont forget to spreat the rep though.
Finnishing the MS mods tomorrow. Keep you all posted. Later.
Old 7-27-08, 12:50   #187 (permalink)
  Total: 57 Power: 5
Peace
NSXR
It is sitting back home in Michigan, still. I spent the last year and a half working as the Powertrain Leader for my school's FSAE team and now I am in Chicago for an internship. This fall I will finally have access to it but with no job and a lot of classes to finish
Old 7-28-08, 12:13   #188 (permalink)
STW
  Total: 445 Power: 3
STW's Avatar
Great pics! Good info on clearance issues too, my new radiator would not fit with such a setup.
Very cool project, I hope you get it running fine
626 '88 Wagon, turbo 2.0 DOHC
Old 7-28-08, 13:57   #189 (permalink)
  Total: 252 Power: 4
We will know soon enough. Thanks for the compliment.
Old 7-29-08, 0:38   #190 (permalink)
  Total: 465 Power: 5
great stuff mate. Looking forward to hearing about it's initial start up!
Teh Telstar can NEVAH lose!
Old 7-29-08, 2:55   #191 (permalink)
  Total: 252 Power: 4
Just added some pictures to my first post in this thread.
Old 8-3-08, 15:09   #192 (permalink)
  Total: 252 Power: 4
Well MS modifications complete. Including removing VB921 coil driver and adding (2)BIP373 coil drivers. Wired them to a DB15 connector and R26/R29 for spark A&B. I used 14 GA wire for all modifications. Mounted the LED's on the top cover of the MS case. So baisically none of the spark accept the signal connection runs through the traces, due to there apparent weakness. All of the leads are heat shrink wraped and new spark harness finnished. Pictures and video in my next post. Later
Old 8-3-08, 15:36   #193 (permalink)
  Total: 252 Power: 4
By lundgren420000, shot with HP Photosmart E427 at 2008-08-03
By lundgren420000 at 2008-08-03
A simple video testing signals, enjoy
ImageShack - Hosting :: hpim1320ya1.flv
Old 8-3-08, 15:40   #194 (permalink)
  Total: 252 Power: 4
Sorry for the poping, that is in my camera, not from the MS.
Old 8-3-08, 17:41   #195 (permalink)
fredio54's Avatar
Who did the work, it looks pretty good :-) Shame the pics are so blurry though...
