#32 (permalink) | |
#34 (permalink) |
hell for the price just get the intake gasket and compare it before buying the entire intake. mabe just a slight modification of mounting holes.
#35 (permalink) |
Well i assembeled my engine tonight and mated the head and block after their one year sepperation. The intake , w/p , exhauste manifold and the rear main seal still have to come back off next weekend. Thins was just a test fit and pre assembly to make sure i still had every thing.
(the bare bueatiful MONSTER) ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 Untoutched ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 By lundgren420000 at 2007-11-24 (All the ARP hardware) ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 (Head studs mounted) ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000 at 2007-11-24 (Test fit with OEM FE-DOHC Headgasket) ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 By lundgren420000 at 2007-11-24 Then applied a generous layer of Permatx Super 300 to both sides and torqued the head to 90 ft-lbs. but in my own way first all to 50 ft-lbs then 75 ft-lbs then finally to 90. I was never so nervious in my life, i was waiting for "PLINK" and i would have gone off the deep end and done some verry bad things. but it worked out just fine. ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24![]() By lundgren420000 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000, shot with HP Photosmart E427 at 2007-11-24 ![]() By lundgren420000 at 2007-11-24 Last edited by lundgren420 : 11-25-07 at 1:28. |
#37 (permalink) |
ya ARP from the ultimate build guide. and as for the cams in-feap ex-fe3n. Ya tis was once a f8, but now it only shares the same intake.
The low-down Ported and polished head, 3 angle valve job, intake collets for the exhauste valves, new (used) intake FEAP cam, new f2t micro-polished crank, new ballanced and cryoed (fe-8 valve) 626 rods, new mains, new rod bearings, bored to 86.5mm, fresh rough hone for crome molly rings, diamond 8:5:1 forged turbo pistons, forged wrist pins, also fresh bb 46 trim garrett nissan turbo, 44mm synapse engineering w/g, synapse engineering bov/bpv (can be used as either one) and last but not least MEGASQUIRT-1 v3. |
#39 (permalink) |
no i cant afford another right now, still better than the f8k1 cam. and the turbo is off a 1991 nissan skyline r32 gts-t type m. If you cane come up with some good specs on it i would greatly appriciate it. I do know however that it uses a ceramic exhauste wheel that doesn't like to be over heated meaning it breaks apart , this limits them to 14psi or lower.
Later i would like to pick up a Holset HE351 for my project but dont know if it will fit. |
#40 (permalink) |
now thats what we like to see!!!!!!!!!!!!!!!! give that man a ciger and a beer
![]() man i like it, i like it a lot. but indeed.. ditch the cams and inlet manifold. if u need oem FE3 stuff let me know. i got some spare engines here and there which i use for measuring only .. even have an alloy sump if u like. anyway good work done there. keep us "pictured" posted ![]() |
#41 (permalink) |
my problem with gettin a better intake cam and intake is fundage im almost broke.
#43 (permalink) |
you and me both brother.
#45 (permalink) | |
afaik, any gtst r32 has the same unit. the later gts25t ones are even worse, some have PLASTIC compressors :-) they only make about 220hp stock, maybe a bit more. the early rb20det made 160ps which is only 5ps more than my rb20de without the t. those were red top, i dont know which turbo they had. so, you will be limited to about 280hp or so max max with that turbo, but thats good power i guess :-) will be a torque monster for sure. |
