Old 12-12-07, 7:38   #61 (permalink)
  Total: 236 Power: 3
lundgren420's Avatar
they looked identical, minus the slightly shorter length due to the fact that they were from a 77mm stroke F8.
1989 Probe GT M/T -my new toy
Old 12-14-07, 17:31   #62 (permalink)
  Total: 344 Power: 3
chief tool's Avatar
dont you mean longer ?
Old 12-14-07, 17:48   #63 (permalink)
  Total: 69 Power: 3
negative, 150mm<152mm & every MM counts in this aspect.
Old 12-14-07, 20:22   #64 (permalink)
  Total: 344 Power: 3
chief tool's Avatar
I thought you were talking about the original F8 DOHC rods....It'd be interesting to know how long they are...
I was aware that the FE 8v rods are 152 compared to the FE3 rods at 150.
I might expect that the F8 DOHC rods would be longer than 152 but shorter than an F2 rod which is 158.
Dont ask me how those lauging icons got in there, thats not meant to happen!
Old 12-14-07, 22:28   #65 (permalink)
  Total: 236 Power: 3
Is the measurment taken from center bore to center bore?
Old 12-15-07, 0:10   #66 (permalink)
  Total: 344 Power: 3
chief tool's Avatar
yes...............
Old 12-15-07, 3:44   #67 (permalink)
  Total: 1143 Power: 5
fredio54's Avatar
LOL
if pin and deck heights are the same, then the rod must be 154.5mm in length right.
( 86 - 77 ) / 2 + 150 = 154.5
Old 12-15-07, 11:48   #68 (permalink)
  Total: 69 Power: 3
the FE3 rod is 152mm right???
Old 12-15-07, 23:59   #70 (permalink)
  Total: 69 Power: 3
well im real lost then, what exactly is the FE3 rod measured in @??? i know alot of the stuff on the solomiata website isn't accurate, but so far thats all i've had to go off of.
fill me in please
Old 12-16-07, 3:59   #71 (permalink)
fredio54's Avatar
you are right, a lot of it isnt, but that is :
http://members.aol.com/FE3N/rods.html
also, i remember measuring one myself a long time back.
Old 12-16-07, 14:06   #72 (permalink)
  Total: 236 Power: 3
Ok so here it is
Cranckshaft lobe 54mm
Wrist pin lobe 21.95
Inside to inside 116.5
so i came up with a length of 154.5mm for the F8-DOHC rods.
Old 12-16-07, 15:55   #73 (permalink)
fredio54's Avatar
Originally Posted by lundgren420 View Post
Ok so here it is
:-) yay, i was right.
Old 12-16-07, 16:30   #74 (permalink)
  Total: 69 Power: 3
so the rod ratio will suck even worse then i had figured. Its still better then a BP tho. I wonder how it will run.............
Old 12-16-07, 20:07   #75 (permalink)
  Total: 236 Power: 3
ya that is why i went with the 626 rods. if you look for "the golden ratio" thread you will find where we were all talking about the rod to stroke ratio of the golden ratio of efficent design. The end was Sick however refering to Mayard's golden rod. Ya it was pretty funny though.
