Old 10-29-09, 19:24   #301 (permalink)
  Total: 312 Power: 5
its alive.
YouTube - P9180004
Old 10-30-09, 16:55   #302 (permalink)
  Total: 90 Power: 4
no sound!!!!! i had to check my speakers :P
Old 10-31-09, 18:45   #303 (permalink)
  Total: 312 Power: 5
Im sorry i didnt realize that my camera had no sound. When i get the exhaust done and take care of the throttle body leak i will post another video.
Old 10-31-09, 19:01   #304 (permalink)
  Total: 90 Power: 4
thank you!!!
Old 11-1-09, 15:17   #305 (permalink)
  Total: 312 Power: 5
For reference, the radiator hose from a 1997-03 Toyota or Lexus 3.0L will fit profectly to connect the upper radiator hose. You need to trim 5" of the long side to make perfrct length. 18.82 at Orielly's.
Old 11-4-09, 13:56   #306 (permalink)
  Total: 312 Power: 5
Ok, well i am almost on the road again BUT, the clutch is giving me problems. It will only dissengage when the car is off.
I can start the car in gear with the clutch pressed in and it doesn't move, like its normal.
However when the car is in nuetral and started i cannot get the it to go into gear with the clutch pedal pressed in.
Clutch disc: Stock replacement (new)
Pressure Plate: Spec Red, RX7 2500lb (new)
Pilot Bearing: Stock replacement (new)
Slave Cylinder: original equipment
Master Cylinder: original equipment
Clutch Line replaced with Cork Sport braided stainless steel (new)
Also i can take it though all gears smoothly when the car is off.
I am going to bleed the clutch hydrolic system again tonight and see where that gets me. I will also chack the clutch fork movement and see if it will travel any further by hand. Wish me luck.....
Old 11-4-09, 19:31   #307 (permalink)
  Total: 312 Power: 5
Thumbs up Sweeeeet!
Problem solved. Solution: Adjust master slave cylinder rod. Pedal was out of spec.
Old 11-4-09, 22:37   #308 (permalink)
  Total: 90 Power: 4
woot!, thank you mazda for leaving a pedal adjustment
Old 11-6-09, 15:28   #309 (permalink)
  Total: 312 Power: 5
A few pics. I am getting the exhaust finished this evening, then off for a little breakin driving
Old 11-9-09, 10:57   #310 (permalink)
  Total: 312 Power: 5
Well its running ok at best. Thanks mostly to the information from Evo626. The ignition advance is set to 14°BTDC. I have no way to tune the fuel from adjusting the VAF so i get fuel cut at 4500 rpms.
Problems that i a have noticed with F2 Managment.
Vacuum advance is 6-18deg on F2 Dissy
Vacuum advance is 12-35deg on FE dissy
VAF needs adjustment. Wideband O2 required.
Also no port in the head or water neck for the factory coolant gauge sensor.
Old 11-9-09, 15:26   #311 (permalink)
  Total: 90 Power: 4
um. NA with factory management your pretty fool proof. just adjust the vaf & use smell from the exhaust to guage its level.
besides that.... why in gods name are you using vacum advance
Old 11-9-09, 17:22   #312 (permalink)
  Total: 312 Power: 5
Im using the stock F2 distributor.
Old 11-10-09, 0:08   #313 (permalink)
  Total: 261 Power: 5
My mate put NA F2 management on his FE3, worst thing he ever did. We changed it to F8-DOHC management and it was marginally better but still not ideal.
How long are you planning to run around like that for? If its going to be semi-permanent maybe try track down some stock FE3 injection gear, even with the extra .2L, it HAS to be better than F2 stuff.
Old 11-10-09, 3:50   #314 (permalink)
  Total: 1299 Power: 5
fredio54's Avatar
Track yourself down a fcuking megasquirt, like you should have in the first place, before you blow it up :-p
Old 11-10-09, 8:29   #315 (permalink)
  Total: 312 Power: 5
I am working on the megasquirt install immedatly. The F2 managment is piss poor at best. Looks like i will be using my MS1 V3.0 with stock F2 injectors.
