Old 1-2-08, 20:43   #1 (permalink)
  Total: 337 Power: 5
Those With Kia FE3, A Flywheel that may fit....
well i was searching for a b2600 bellhousing on the net and I came across some pics of a b2600 flywheel(the one with a mazda engine, not mitsu). I think it may work on a kia fe3 with the 8 bolt crank. Non of my local auto stores have one in stock, so I can't verify for sure.
here is what i got, correct me if I'm wrong..
90-93 b2600
uses the same 240mm pressure plate and clutch disc as an f2t.
has an 8 bolt crank pattern like a kia fe3
also has the same amount of ring gear teeth (116) as an f2t.
now there could be a bunch of other reasons why it wouldn't work, but I think if someone can get the 2 flywheels in person to compare, there might be a chance. I am still searching auto stores to see if they have one in stock.
if it does fit I would be pretty upset, because I spent $400 on a custom aluminum one.
Stock: 15.446 @ 88.78 F2T Best: 12.71 @ 104
FE3T: 11.941 @ 99.03 (missed 4th)
470 WHP Turbonetics 50 trim @ 30psi
videos:http://videos.streetfire.net/uploaded/Shwine617.htm
Old 1-3-08, 4:40   #2 (permalink)
  Total: 1203 Power: 5
fredio54's Avatar
damn, thats a good find schwine!
if thats the case it means easy flywheel swaps for me in nz because those engines are common there. f2t isnt...
if i convert to a diesel crank and use those i'm golden :-)
well done K if it lets me :-)
fred.
Old 1-3-08, 5:26   #3 (permalink)
fredio54's Avatar
i added a link here to the index thread. will pull it back out if it turns out to be no go.
Old 1-3-08, 5:33   #4 (permalink)
  Total: 144 Power: 4
I think may be true as i just had a custom 2600lbs pressure plate made and it was from a Ford Courier (it was 240mm) which I know is a rebadged mazda.
mazda 626 turbo
Exedy - Details
b2600 petrol here was 250mm
Exedy - Details
Exedy - Details
However the b2600 petrol carby matched (and uses the same clutch in the cat)
Exedy - Details
Might be worth a read
:: Project Zero G :: - RX7 Transmissions
roth251 is offline   Reply With Quote
