Closed Thread
Old 3-5-08, 23:04   #136 (permalink)
  Total: 438 Power: 5
RbluEMx6's Avatar
Originally Posted by Oparatior View Post
so would these rods work in a F2T ? if yes/no why?
im intrested in getting some if they will work for the F2T aswell
No they wont work. The F2T rods are longer than the FE rods.
-Rick- 88 MX6 GT Celeste <--Cardomain Page Updated 7-8-08
Boosted on an Electromotive TECII standalone.
FE-DOHC rebuild 265hp, 290ft/tq @ 15psi
'08 FORD Ranger Sport
RbluEMx6 is offline
Old 3-6-08, 0:44   #137 (permalink)
  Total: 26 Power: 1
and shorter rods would mean what, less compression?
Oparatior is offline
Old 3-6-08, 0:53   #138 (permalink)
  Total: 438 Power: 5
RbluEMx6's Avatar
You would have no compression. The FE is a square design at 86x86mm where as the F2 is 86x94mm. Quite a difference in stroke.
RbluEMx6 is offline
Old 3-6-08, 2:01   #139 (permalink)
  Total: 210 Power: 4
RbluEMx6: There is a big diffrence between FE and FE3, so please learn which engine you are talking about. Right now when posting in the FE3 section there is no problem, but there could be further down the road.
-:|my GC|:-
Mazda 626 lx coupe 1984, 2l FE carb., 99% rustfree, Waiting on shelf: Custom Koni's + Koni springs
-:|my GD|:-
Mazda 626 glx hatchback 1990, FE-DOHC, Dutch FSTbar, MS2 PCB v3.0, Innovate LC-1, Mitsubishi TD04-15T @ 0.55bar. Soon TD05H-16G + new manifold
eraezer is offline
Old 3-6-08, 9:18   #140 (permalink)
  Total: 1143 Power: 5
fredio54's Avatar
You would have little compression. All FEs use a square design at 86x86mm where as the F2 is 86x94mm. Quite a difference in stroke.
You would have little compression. The FE3 is a square design at 86x86mm where as the F2 is 86x94mm. Quite a difference in stroke.
All FE engines dohc, sohc 12v, sohc 8v are by nature 86x86, however bore doesnt matter a damn. Only stroke. I know you realise this, but like eraezer said, others may not. The latter quote would be preferred :-p
Correct, not much, you could calculate it, but at the top of the stroke (if your pistons didn't fowl the crank or block) you would be 8mm below deck and your compression ratio would be around 4:1 which is a little too low even for stupidly high boost. Worse though, you would have zero quench.
4:1 is not = 1:1
Fred.
fredio54 is offline
Old 3-6-08, 20:08   #141 (permalink)
  Total: 438 Power: 5
RbluEMx6's Avatar
Still in the process of learning all there is to know about this engine guys.
RbluEMx6 is offline
Old 3-7-08, 13:48   #142 (permalink)
  Total: 156 Power: 3
4mm actualy ! but still its no good!
bakmans is offline
Old 3-8-08, 5:55   #143 (permalink)
fredio54's Avatar
150 mm vs 158mm
crank in same position
what am i missing? or are you confused? or am i?
fredio54 is offline
Old 3-9-08, 12:16   #144 (permalink)
  Total: 156 Power: 3
sorry i was wrong!!
had the f2t and the fe3 cranck thing in mind. stroke opf the f2t is excactly 8mm longer than the fe3 and in that case the postin would raise 4mm above deck ( if yuo use a 2.2 crank in a fe3 with f2t or fe3 pistons)
but as stated freds right!
bakmans is offline
Old 3-19-08, 1:56   #145 (permalink)
  Total: 10 Power: 1
is this BB still active ?
GMANS89GT is offline
Old 3-19-08, 5:35   #146 (permalink)
  Total: 1004 Power: 5
Dutch's Avatar
i believe so yes...
1989 Mazda 626 GT-LX 2.0i-16v coupe soon 2 be turbo twin-cammed
half owner of an 818S 1300cc 1980
You, sir, are full of awsome.
Dutch is offline
Old 3-19-08, 10:35   #147 (permalink)
  Total: 14 Power: 2
u can put me up for a set.
zo0m is offline
Old 3-19-08, 12:21   #148 (permalink)
  Total: 85 Power: 3
when do we need to pay some money? lol i dont wana spend it on other [shizzle]
fe3t b2200 is offline
Old 3-20-08, 0:29   #149 (permalink)
  Total: 10 Power: 1
I NEED A SET , AND ALSO WOULD LIKE TO KNOW WHEN THE CASH IS DUE .
Old 3-20-08, 3:02   #150 (permalink)
Dutch's Avatar
ssssssssssst
Dutch is offline
Closed Thread
