Closed Thread
Old 1-18-08, 9:10   #16 (permalink)
  Total: 139 Power: 4
i need to ask something. anyone had problems with the stock rod? the stock rod its a very strong one and IMO the stock one can handle a lot of power. If someone gota interest in a forjed rod for our engine, thats a good option for those who wants run N/A to make it lighter. its a good option make a forged custom rod to the fe3 engine with the F2T crank and FE3 pistons.
Turbo Mx-3 GS with FE3N Engine Swap with 425whp
Owner of a 10 seconds FWD Mazda
http://www.youtube.com/watch?v=MJqBkD2zwgA#GU5U2spHI_4
Bo0sted_Rafi is offline
Old 1-18-08, 14:01   #17 (permalink)
STW
  Total: 422 Power: 3
STW's Avatar
Investing on custom short rods to accommodate stock pistons isn't like betting on the wrong horse. It's like betting on a jar of hide glue...
I'm a bit in the middle of things, if the rods are good for revving a boosted stroked DOHC I'd be in, but there's certain affairs in the way that will have a strong impact on future development of the engine, can't say anything until I've gotten them cleared.
626 '88 Wagon, turbo 2.0 DOHC
STW is offline
Old 1-18-08, 15:20   #18 (permalink)
  Total: 1176 Power: 5
fredio54's Avatar
its still horrible. no matter how many times you look it up :-(
piston pin height is the way to go for any serious power. if you just want the 2.2 bottom end, use an f2t. if you want the top end, use an fe3, if you want both, don't skimp.
just my thoughts, mileage may vary.
fred.
fredio54 is offline
Old 1-18-08, 15:47   #19 (permalink)
  Total: 58 Power: 0
You want to get the longest Rod you can for a stroked engine and a good rod ratio . Thats why i got all my stuff custum made. Moved the pin up as high as possible and and a longer rod 5.950" center to center
Stroker is offline
Old 1-18-08, 17:15   #20 (permalink)
  Total: 139 Power: 4
But the question is, anyone had problems or broke a Stock Rod?
Old 1-19-08, 1:53   #21 (permalink)
  Total: 919 Power: 5
you can always do like randys did, and use some slightly modded v8 rods with custom pistons.
thats what i did on the KL, used chevy wrist pin ford stroker 347 rods. 8 h beams for $300 FTW
01 Yamaha YZ250
98 Ford Ranger 3.0L
rebel2k4 is offline
Old 1-19-08, 4:15   #22 (permalink)
fredio54's Avatar
You are onto it stroker.
yes! no pics to show it, but the guy that let me know was a straight up sort.
extended use over the 500 crank hp mark upto 7500rpm = bent rods
a few runs down the drag strip doesnt count as extended use. hence you have been ok so far :-)
i'd say 400whp or so (450crank) is a reliable limit for them with a stock stroke!!! once you change that, the ball game is entirely different. (ie, worse)
fred.
fredio54 is offline
Old 1-19-08, 7:44   #23 (permalink)
  Total: 150 Power: 2
Keeloh's Avatar
I haven't had any problems what so ever with my rods in my FE3.
91' Lx to 89' GT Swap/T-Bird Turbo/Zebel Housing/2.5" Downpipe,Test Pipe,Sebring Exhaust/Probinator Chip/15psi/Walbro 255LPH Fuel Pump/8.5mm Magnecor Wires/Msd Blaster 2/P&P Head/Fidanza Aluminum Flywheel/Exedy Clutch/AWR Mounts/AWR Trailing Arm/GT Rear Disc Conv/Subaru Front Dual Calipers/Pacesetter Short Shifter/Upper Bar from Bulldog Racing,Rstb and Lower Tie Bar/ 2 MazdaSpeed Bucket Seats with 4 point Harness.
Keeloh is offline
Old 1-19-08, 8:38   #24 (permalink)
  Total: 139 Power: 4
fred.
What do you mean with extended use? IMO, anybody got a daily driving car with 500whp everytime. We use our cars for everything, but obviously, we not use hi boost to run in the street.
"A few runs" with 550whp+ when you use slick tires, a lot of boost, some nitrous, and wheelie bar, the engine suffers more than a 300whp engine in a street car.
Old 1-19-08, 10:38   #25 (permalink)
STW
  Total: 422 Power: 3
STW's Avatar
A circuit track would count ase extended use. The biggest difference is that while a drag engine will see enormous rod forces, the track engine will se full power for much, much longer time without chance to really settle down in between, also the engine may be over revved past the shift point because of track topology and so on.
When the rod is run at great load, the material will absorb a part of the mechanical energy, and the energy can cause alterations in the metal properties. On a drag car, the engine only needs to provide full power for a number of seconds, and is then let cool down. On a track, even one lap will take minutes and have a large portion of it driven at full power. The process is partially reversible, but the amount is rather a constant number rather than percentage; in a drag engine, the reversibility will cover most of the alterations, but after a long and heavy run, the same amount of reversibility will only recover a small fraction.
STW is offline
Old 1-19-08, 11:07   #26 (permalink)
  Total: 770 Power: 3
defiler's Avatar
IIRC Fallguy ran his FE3 at the track a heck of a lot more than a "few times" and never had a single problem with his rods.
89MX6 GT 4WS
90 Probe GT
If people want to be spoon-fed info, not search, and feel all happy-go-lucky and live in a nice Utopia, then thats what PP is around for.
defiler is offline
Old 1-20-08, 14:12   #27 (permalink)
  Total: 355 Power: 5
i think the F2T pistons are alot weaker then the stock fe3 rods... spending the cash for stronger rod's, to use f2t pistons would be backwords IMO. spend the cash on good pistons on fe3 rods. will be enough for what alot of us are doing.
~ChiPoC~
monoxidechild is offline
Old 1-20-08, 14:32   #28 (permalink)
  Total: 330 Power: 5
i agree that the stock rods are very strong. But a new set of lighter forged rods that are balanced within +-1 gram with ARP bolts for $260 would be a steal. I am not positive on them being lighter or if they come with arp bolts, because I am still waiting for a reply.
Stock: 15.446 @ 88.78 F2T Best: 12.71 @ 104
FE3T: 11.941 @ 99.03 (missed 4th)
Best MPH: 12.24 @ 117.03
videos:http://videos.streetfire.net/uploaded/Shwine617.htm
shwine617 is offline
Old 1-20-08, 15:31   #29 (permalink)
  Total: 355 Power: 5
i agree. the price is insane!
i paid a almost 700 for my pauters in my f2t in the 92pgt. if this does end up having enough intrest, ill probably pick up a set just in case something happens with the current stock rod's.
~ChiPoC~
Old 1-21-08, 7:09   #30 (permalink)
fredio54's Avatar
STW is right on the money!
this is the engine that died. it not only did that many runs, but was used on the street with full boost daily. not detuned for the street. it bent its rods in the long term from accumulated stress. rafi will find this out some time if he does enough drag runs, or thrashes the car hard enough on the street or track.
the rods have a limit, they are not golden. everything has a limit. the guy that bought fallguys engine found it before the rest of us after a number of months hammering it hard.
you can build your engine to put out 500hp for a few months or for a few 100 thousand k's. its up to you.
new rods provided that they are meatier (not lighter) with better fasteners to match are a good thing.
fred.
fredio54 is offline
Closed Thread
