Old 6-21-08, 6:45   #1 (permalink)
  Total: 58 Power: 0
Question F2 turbo crank
I need to no how much HP can it handle and what is the highest RPM can it handle. An have you ever heard of some body that has broken one
Stroker is offline   Reply With Quote
Old 6-21-08, 8:59   #2 (permalink)
  Total: 226 Power: 2
Never heard of anyone breaking one. Never heard of anyone throwing a rod either.
So noone knows how much hp it can really handle.
The first things to go when chasing big numbers seem to be the headgasket or the piston ringlands.
Mostly due to a bad tune inducing ping / knock.
mx_masta is online now   Reply With Quote
Old 6-21-08, 17:47   #3 (permalink)
  Total: 351 Power: 3
one of the guys from NZ had a picture in a thread somewhere on this site with and FE3 stroker that threw a rod...
89 626 5 door F2T
Old 6-21-08, 18:01   #4 (permalink)
  Total: 2594 Power: 5
Uhhhh, nagatory. Look at it again anf you'll see SR20. The answer is 1,000 internets and +5 lolDongz for pict0rz.
Originally Posted by r32mx6
Originally Posted by SixSick6
u mom smoke a dose pipe.
Old 6-21-08, 18:36   #5 (permalink)
  Total: 252 Power: 3
lundgren420's Avatar
The picyture was a KA20 and it was posted by Fredio54, FE3T said that he threw a rod at 412 hp on a stock 2.0 stroke. Although he may have been working on a stroker. Ask him.
1989 Probe GT M/T -my new toy
Old 6-21-08, 19:02   #6 (permalink)
  Total: 58 Power: 0
So iv built my engine its got all good stuff but cast crank if had every think done to the crank . I no its a stroker engine whats the limit should i rev it to and how much horse power do you think. i have spent a lot of money on this engine an the weakers link to me is the crank I have a R2 crank at home witch is a forged steel or cast steel different casting marks to the f2t crank i do want to rev the engine to 8k-85k what do you think. I do not want to break it but im after at least 500whp-550whp for now big turbo Gt51r
Old 6-21-08, 20:26   #7 (permalink)
  Total: 226 Power: 2
AFAIK yo are treading unknown territory revving an F2 crank that high, good luck!
Old 6-21-08, 20:28   #8 (permalink)
  Total: 252 Power: 3
Look at piston speed for the answer to that question. The piston speed at 6500prm's is roughly 4015 that is the max you want to see for sustainable time. The rev limit of FE3N with stock rods is 7000 and the F2T has a 6500 or 6750 revlimiter. I will stick by the F2T ands limit my self at 6500. The torque should be signifigantly higher with the extended stroke and this will also change the spool charicteristics of your turbo. Also look at Boostedrafi, his car club has a factory crank and factory rods putting down 585hp and like 485 tq. Proof enough for me that the crank is stout.
YouTube - Mecanica Galdo GLC 10.35 @ 139mph
Old 6-21-08, 20:42   #9 (permalink)
  Total: 252 Power: 3
The show stopper
Originally Posted by Bo0sted_Rafi View Post
Well guys, we went to the dyno tonight to confirm the last modify of our engine (Some NOS) and we get a great results. Last week we get the car to the dyno and we got 552whp with some problems. Tonight we get 584whp and 457 lbs of TQ.
I will post the track results this week because we gonna go this wednesday.Stay tunnned!!!
PD. Now we got WB too
Old 6-24-08, 17:34   #10 (permalink)
  Total: 609 Power: 3
carcenomy's Avatar
I always thought the cause of failure was stress induced under the mass and momentum of rotating parts like the piston/rod assemblies and that the most common failure point on the FE-DOHC (stroked or not) in high speed applications was the bolts?
But I'm probably wrong.
Old 6-25-08, 4:19   #11 (permalink)
  Total: 58 Power: 0
Originally Posted by lundgren420 View Post
The show stopper
This engine is only 2.0 litre not 2.2
Old 6-25-08, 7:51   #12 (permalink)
  Total: 252 Power: 3
His new priject is though. There was a few guys with 2.2 strooker FE's but i dont know where they are now. So far it looks like Myself, Stroker, BoostedRafi, and i think LMB_ are stroking the FE. I cant wait till nex week, I am taking the whole week off and putting mine in. Then right after it starts it goes straight to the dyno for tunning and breakin proceedure.
Old 6-25-08, 16:50   #13 (permalink)
  Total: 156 Power: 3
im working on one 2 with sr20det pistons. waiting on the scat rods but that might take a while before everybody paidup
bakmans is offline   Reply With Quote
Old 6-26-08, 21:04   #14 (permalink)
  Total: 40 Power: 5
The f2t cranks are pretty stout, i dont think overrevving will be the thing that takes one out. other things are going to fail first. I have already built an fe3 stroker and thrown a rod. So it can be done, my machine shop even said that the crank could have been used again. i have since rebuilt the stroker fe3, and ran it as a daily driver for a few months. I set the rev limit at 7k, when driving hard i usually only took it to 6500 though. i have taken it to the limiter, and it was able to get there with no problem, wouldnt say to do it all the time, and wouldnt really want to take it any higher either. I dropped the comp for a turbo, but so far have not put one on, still in the garage no time or money...it could still almost keep up with a stock f2t at 10psi (don't think the car was running at 100% when we raced though) and have had a couple prelude owners tell me my car would still outrun theirs (stock) so go fe3
as a side not the rev limit on the f2t and f2 n/a is 6200, not 6500...
