Old 6-17-09, 3:35   #1 (permalink)
  Total: 10 Power: 0
88 mx6 heater problem
hey guy im shane,
ive just joined up.
i have recently bought a 88 mazda mx6 2door coupe manual 2.0 doch
i am having trouble with the heater as in it only blows cold air out not hot air.
What are the possible probs why this would occur as it is winter here in n.z
and i need it working asap,
fuse or actual heater unit itself faulty
any help appreciated
cheers shane
626bandit coupe is offline   Reply With Quote
Old 6-17-09, 6:32   #2 (permalink)
  Total: 10 Power: 0
got water in the engine cooling system?
heater core clogged?
Mindtrusted is offline   Reply With Quote
Old 6-17-09, 6:37   #3 (permalink)
  Total: 487 Power: 5
chief tool's Avatar
Your in the wrong section.......
however, check that the heater core has not been bypassed, as the core tanks are notorious for splitting and leaking coolant.....
most people bypass the core so as to avoid the cost and or time and effort to change the core
Old 6-17-09, 17:50   #4 (permalink)
  Total: 10 Power: 0
so the only way to get hot air is to replace the core it self, were about is it situated in the dash and is it really that difficult replace,does it involve taking the dash out
cheers shane
Old 6-18-09, 1:06   #5 (permalink)
STW
  Total: 533 Power: 5
STW's Avatar
It's not difficult per se, but does take quite a bit of effort. You do have to take the dash out, here's a shot of the core:
The white thingie in top center. If the core is not bypassed, you could try and flush it, if it's clogged it should clean out.
1988 626 GT Wagon, 2.0 DOHC Turbo | 1992 Toyota Carina e GLi | 1991 626 GLX Hatch AWD 2.2l
STW is online now   Reply With Quote
