Mazda Fe Stroker piston - Mazda MX-6 Forum
post #1 of 31 (permalink) Old 1-14-11, 13:43 Thread Starter
Hi Guys
What pistons would work with the stroker motor, got a forged rod standard length ?
Heard the SR20det or 4g63 or 3sgte forged piston will fit ?
nevillehome is offline
post #2 of 31 (permalink) Old 1-14-11, 21:30
Power: 0
Pistons
Originally Posted by nevillehome View Post
Hi Guys
Hi Jacob Iv got some Ross forged Pistons that will work CH 1.279 to go with standed rods to make a stroker kit $550 there yours
mazda1 is offline
post #3 of 31 (permalink) Old 1-14-11, 21:41 Thread Starter
are these new pistons ?
where is your location ?
post #4 of 31 (permalink) Old 1-14-11, 23:26
Power: 0
Pistons
Yes they are new Sydney Australia
mazda1 is offline
post #5 of 31 (permalink) Old 1-14-11, 23:44 Thread Starter
What size pistons are they ?
How much would it cost to ship to South Africa ?
post #6 of 31 (permalink) Old 1-15-11, 0:33
Power: 0
Ross pistons
87mm $70
mazda1 is offline
post #7 of 31 (permalink) Old 1-15-11, 12:06 Thread Starter
can you send me an picture of the pistons please ?
post #8 of 31 (permalink) Old 1-15-11, 13:30
STW
STW's Avatar
4G63 or 3SGTE pistons do not fit FE stroker!
I think I have been along perpetuating this myth. It was before I began to verify the validity of the information I'm given. Apologies.
They have compression height of 35mm, only 1mm less than stock piston; you need 4mm, or 32mm. SR20DET pistons are the only pistons useable, but only worth getting for cheap; the lack of valve pockets is quick to cause grief, and they have a bit too little dish volume for really high boost. Also, don't go past 86.5mm bore, 87 *will* crack under boost, this is proven by many, here and other forums. I bored mine to 86.5 and filled the block up to core plugs to be sure. Wall thickness really is an issue with FE DOHC.
4G63 or 3SGTE pistons won't destroy a regular 86mm stroke engine, but then you'd lose a lot of squish without extra thin gasket. SOHC rods on the other hand are 2mm taller than DOHC's, which would ram the pistons into the head. Using an extra thick gasket (~3mm!) would help but again that creates other problems.
1988 626 Wagon GT 2.0 DOHC Turbo | 1988 626 Hatch GT 2.0 DOHC | 1991 626 GLX Hatch AWD 2.2 l 1998 Volvo 940 STW Turbo Classic | 1988 626 Coupe GT 2.0 DOHC
STW is offline
post #9 of 31 (permalink) Old 1-15-11, 20:55
Power: 0
Stroker piston
I'v been using 87mm bore for over 6 years never cracked a bore and running high boost 30-35 psi. you must have heat props if its cracking.And i have had my cylinder walls measured there is about close to 5mm thick going to 87 no worries. Iv got a team who will build my next motor an i no by talking to them they have the 2j with less cylinder wall thickness then the fe3 and they are making 330hp per cylinder. If its cracking its heat proplems water temperuters
mazda1 is offline
post #10 of 31 (permalink) Old 1-15-11, 21:53 Thread Starter
are these custom made ?, or for what car are they for ?
post #11 of 31 (permalink) Old 1-15-11, 23:26
Power: 0
Pistons
they are custom made for the fe3 stroker i had made up and changed my mind il send you pictures haveing props with camera
mazda1 is offline
post #12 of 31 (permalink) Old 1-15-11, 23:45 Thread Starter
Why did you change your mind ?
Please send pictures to me please
post #13 of 31 (permalink) Old 1-16-11, 0:42
Power: 0
stroker pistons
I changed my minedthe rod ratio was not that good have you got a picture mobil i can send it via that send me your number
mazda1 is offline
post #14 of 31 (permalink) Old 1-16-11, 1:33 Thread Starter
+27823315269
post #15 of 31 (permalink) Old 1-16-11, 5:24
Power: 0
Ross pistons
I have sent the pictures to your email
mazda1 is offline
