FE3 information, specs, performances, where to buy, parts, and every thing else
I guess that when people do a search for FE3 they come up with alot of useless threads telling people to search and when they do ask they get a lot of harsh answers. (sorry to all that have recieve harsh answers from me)
So to make it a little easier to find FE3 info I have made this thread. Feel free to add on to anything I don't cover. First question: What is FE3? Fe3 is a 2.0l 16v DOHC engine that is found in euro and japanese spec mx6, 626, and capplea cars. 1998cc 121.9 cu in. 2.0 liters 86 mm bore 3.39 cu in 86 mm stroke 3.39 cu in Aluminum head, cast iron block Dual overhead camshafts, 16 valves Here is a pic from FE3Ts site. THis motor cam in a few different trims. 9.2:1 compression on cat models 10.0:1 compression on non cat models 170bhp@ 6000 rpm 10.0:1 models 160ft/lbs@ 4500rpm 10.0:1 models 148bhp@ 6000 rpm 9.2:1 models 140ft/lbs@ 4500 rpm 9.2:1 models (from JayB's website) Will it fit my car? As long as you have a 88-92 MX6,626, or Probe. Is it a direct fit? Yes, everything bolts right up. Can I use the DX/lx tranny with FE3? Yes, just be carefull with your shifting and if your planning on adding boost you may want to go to the GT tranny Can I use the F2T or F2 ecu with FE3? Yes, you can as long as you extend the dissy. You can use the F2 or F2T ecu but it will not running the FE3 as it is intended. A better option would be to use a standalone ecu or FE3 ecu. Can I use the BP ecu from a protege? Yes you can as long as you have all the wiring and proper conections. Whats is VICS? The intake are also a jewel. its a variable intake with 2 sets of runners. 1 long set for low rpm torque and 1 short set for high rpm power (picture from FE3Ts site) Also you can control the vics operation with a stand alone ecu or an rpm activated switch. What parts do I use for FE3? You can use 98 KIA sportage parts, like the water pump, timing belt, head gasket, pistons, etc... Use F2 oil filter, miata spark plugs or just go to the parts store with the ones that came in the car. As miata sparkplug wires. What is the performance of the FE3? The FE3 is just a little faster than the F2T. It revs higher in the rev range but doesn't produce as much tq as F2T. You can expect low 15s runs from a well tuned FE3 and posably 14s if you a good driver. Also It has been noted that FE3 has a top speed of just over 280kmh or 150mph. Was there ever a turbo FE3? Yes, it was used in a rally car in the early 1990s. Only 28 were made. They the engine code is FE3T. They are not avaiable. Can I turbo FE3? Yes. Turbo FE3s produce huge amounts for hp. They are capable of over 500hp with a turbo. JayB had his FE3-T runnig 11s 1/4mile times. Where do I get FE3? Check with your local Japanese Engine Imports. Or check to see if JAyB has any. Also there are avaible in Colorado at a place called All Japanese Engines Ph: 303-234-9528 They should be able to souce one. But make sure its complete. Here are some more sites and things to read regrading FE3: FE3Ts site JayBs site Randys site http://www.mx6.com/boardnew/showthre...&highlight=fe3 (Prices of FE3 motors) wiring diag (fe3 ecu diagram) valve keepers (Service bullentin: For FE3 owners) evo vac lines (Evo needs FE3 help!!!!) evos fe3 coming in soon (FE3 coming in soon) FE3 vs F2T FE3 started kia part numbers vics controler (Evo needs VICS help) FE3 in probe (FE3 in a Probe!) rev limting problem (Rev Limiting Problem On Fe3 !!!!!!! Helppppppppp) FE3??? (F2, F2t, Fe3, Fe3t????) FE3 thermostat (Fe3 thermostate change=power increase) Fe3 debate (Top performance capabilities of a F2T, Fe3, Fe3T) evos thoughts on fe3 (Evos thoughts on FE3) cheap turbo for fe3 (Cheap turbo for FE3) misconspections about fe3 (Common missconspections about FE3) Hope this helps. Sorry about being so harsh, I didnt relieze how many useless posts on FE3 there really are. Hope this helps. And fell Free to add to this post. evo Last edited by evo626 : 3-10-03 at 3:11. |
#4 (permalink) |
evo, I'm guessing the manual trans that came with the FE3 in the Japan cars isn't any stronger than the MTX in our cars and also came without a LSD?
Does the FE3 use hydraulic lifters and are they located in the tip of the rocker arms like the F2? I would really like to see a close up shot of the FE3 with the valve cover off. |
#5 (permalink) | |
It's no such thing as a stronger Mazda tranny, even if it's from Japan, Africa, Russia, Austrailia, or what ever it is... It's no such thing, the only thing maybe if it's LSD or not. All Mazda trannies are same strength world-wide (WEAK) |
Jay B
MAXX Motorsports http://www.maxx-motorsports.com Tech 1-407-295-9047 Fax 1-407-295-9074 90 C-2 FE 16V Turbo 88 Mazda 323 GTX 4WD turbo 93 Ford Probe GT soon KL-ZET |
#6 (permalink) | |
Re: FE3 information, specs, performances, where to buy, parts, and every thing else
Everything is edit above... |
Jay B
#7 (permalink) |
Thanks JayB. I figure I would get the FE3T rally engine number off.lol But everything else looks preety good. (I hope)
Now at least there is one good post for people looking for fE3 info. Took me about 2 hours to complete. And I had to shift though 21 pages listing all the different posts on FE3. evo |
#10 (permalink) |
Everytime I see something or hear something about the FE3 I wonder who invented this marvelous magical block... it's such a sweet engine, it's a mirracle inside and out, plus it's a verry beautieful block to look at.... it brings tears in my eyes!
LOL I want onenow, will be getting me one next year, and fit it shortly after that (if dutch626 has the time to help me ) then I will mod the crap out of it and hope to have a faster block then jay-b has some day... lol |
Owner of a 626 Sedan 1.8-12v
It soon will be a 2 liter |
#12 (permalink) | |
Easy 400whp with 20 psi of boost with no cams, headwork, no nothing...very easy!!!! |
Jay B
#13 (permalink) |
I wouldnt say jealousy? More than a few times Ive seen posts that ask questions right under another post that asks the same question...most all of the info is conatained in a search and a little bit of time spent reading,the turbo chat site on yahoo groups is very informative as well.Evo just took the time to condense it...but its all there
