Help me Time my FE3 PLEZZ
Doesa anyone have a pic of what a timed engine looks like where to set the intake cam ehaust cam I already know the crank shaft pulley must be set to the mark on the oil pan. pease help
93 Mazda 626 DOHC FE3N Turbo bonnet feed intercooler, Sequential HKS B.O.V, Zex high performance plugs,
NGK blue wires Walbro 225lhr pump, Car Tech RRFPR , with 460cc RX7 injectors,HKS High Flow Filter, Free Flow 2.5" exhaust Pipe,AC S7 Neon boost & Rich Lean gauge soon to add a chip upgrade |
#2 (permalink) |
the nib on the crank should point upward, and the letter's on the cam pulley's should point to the little arrow on the inside of the cam pulley cover, iam assuming that the fe3 in your 626 you did yourself and 'cause it's turbo your running a standalone maybe? if that is the case then i can't help you with the ignition timing what i just gave you was base timing. hope it help's.
PEACE richard |
mods:HP engine kit,9.0-1 comp pistons,act clutch,9lb flywheel,h/f oil pump,toga valve springs,napa metal head gasket,3 angle valve job,lightend pulley 2nd gen dropzone springs 2.5" drop,muffler,short shifter,cone filter,drilled and slotted zinc coated ebc's, ebc green stuff, s13 headlight(triple pro)
future mods: X-KIT, mazdaspeed wheels, tokico blues, 440cc rc injectors, rear disc conversion. Units unity through sport unit-s.org |
#3 (permalink) |
Thankxz
Hey thank you 91maz626lx I did it and it worked now I'll take some pics for others to see
#4 (permalink) |
no problem glad i could help man, now let's see those pics
#5 (permalink) |
how much boost r u going to run? and what r u running to manage the fuel?
