Well, I guess the time has come to part with my car. The throw out bearing is almost gone and that along with the other things it will need are more than I can do at this stage in life. If i had a garage, I would not sell it as it still runs and drives well. It has never left me stranded and has only needed slave cylinders as I would guess the clutch is getting thin. It doesn't slip and will kill the car if you forget the parking brake is on. I am the second owner and it was purchased new in Oak Ridge,TN. It was hit and fixed before i bought it, but the paint blistered when my garage burned down 10 years ago. the heat also cracked the windshield and warped the front bumper cover. I have a good one in the same color. I also have another drivers side door with the glass
because mine is worn out. Bad hinges, window slides and previous damage repair. I also have a non GT deck lid and the third brake like for the back window. I wanted to remove the spoiler, but not have to deal with filling the holes. I have two sets of wheels and tires. The factory five spokes have the wrong size tires on them. The mesh wheels on it are off a 929 and have fairly new tires. I converted the drivers seat belt to a manual model. Passenger side still is the motor mouse. Front rotors are drilled. I have the back ones too, but not installed along with braided front brake lines. Car has Tokico blue struts, eibach springs. Also have a Prob rear sway bar not installed. K&N drop in filter, along with a cone filter and adapter. 2.5 cat back system with a flow master, . I also have a chipped ECM too. Car has been in a hail storm, so it has that damage. I also have new belts and hoses, but not installed. Decent stereo and speakers. A/C works, but it has a toggle switch to turn on the compressor. Never found the issue, so I did a switch. It's old, tired and I charge the system every year, plus some but it's cold. Leaks some oil and burn some. It's also due for a water pump and timing belt. Probably other things I'm forgetting. PM me and I'll give you my number to discuss those things. Misc. other parts including what ever stock parts I removed. $1500 or best offer. PM or email me greghime@comcast.net which is probably the fastest way to get a response.
Thanks
Thanks
