Originally Posted by D'sMx-6
I'm interested in the JDM climate control. Did you have this hooked up and how do you install it? I think I read you need some kind of sensor in order to make it work correctly. Let me know asap.
I ended up finding the part I needed and hooked it up. I dropped the price a ton from $295. The reason I priced it that way is due to the fact that it is the only one I know of that works in the states but mainly due to cost to me for the JSPEC wiring harness which I am including. You will need to know your way around the backside of your dash since it is a complete replacement for your current wiring harness.
If you need a tutorial for install I will walk you thru it. I will also send it connected as much as possible. Included will be TWO AUTO A/C head units and a ton of extra parts in case you break something like I did. I will have pics up tonight hopefully.
