Go Back   MX6.com > Open Forums > For Sale/Wanted > FS: Parting Out
Old 5-3-08, 12:24   #1 (permalink)
  Total: 10 Power: 0
parting 93 mx-6 ls
i have a 93 mx-6 ls v-6 auto the car has 140,000 has all power options let me know what you need i give ya good price shipping including
mo_6 is offline   Reply With Quote
Old 5-3-08, 12:49   #2 (permalink)
  Total: 13 Power: 1
all stock or is there aftermarket parts on it?
mflbrody is offline   Reply With Quote
Old 5-3-08, 12:54   #3 (permalink)
  Total: 10 Power: 0
all stock
Old 5-3-08, 13:17   #4 (permalink)
  Total: 10 Power: 0
if some one wants the whole car 700 takes it needs radiator to be complete
Old 5-3-08, 15:35   #5 (permalink)
  Total: 10 Power: 3
I could use the wiring if you still have it. I need the main engine harness, underhood electrical, under dash wiring, and maybe ecu and fuse boxes. Let me know if you are willing to do this.
digitized is offline   Reply With Quote
Old 5-3-08, 20:04   #6 (permalink)
  Total: 10 Power: 0
i will. let me know exactly what it is that you want, down to the part so i know what to pull. then i'll give a price
Old 5-4-08, 10:40   #7 (permalink)
  Total: 10 Power: 3
I definitely need the engine harness that comes around the front for the starter and alternator. Also the wiring under the dash, specifically concernerd with brake, clutch pedal and ignition. The other thing I need badly is the underhood relay box.
It might be easier to pull this with the entire engine wiring that goes around the back of the motor for VRIS, etc. I would take it all as one piece, these all get wound together and go into the ECU.
Old 5-4-08, 11:20   #8 (permalink)
  Total: 10 Power: 0
it is an auto i dont know if this wiring will work considering there is no wiring for clutch i have started pulling the harness
Old 5-4-08, 11:36   #9 (permalink)
  Total: 10 Power: 3
It will work. I swapped a MTX into my auto and the wiring was all there. You should have two plugs not used where the clutch pedal would be. I also have a 93
Old 5-4-08, 20:33   #10 (permalink)
  Total: 16 Power: 1
Got any driver side window switch? (the master switch?) oh and if it's possible the wiring harness for the switch also?
93 MX6 LS, 5 Speed. A beater car for now.
KiwiFlavor is offline   Reply With Quote
Old 5-5-08, 14:21   #11 (permalink)
  Total: 10 Power: 3
Hey, I got a complete set from Hughes. Thanks again for trying.
Old 5-5-08, 18:14   #12 (permalink)
  Total: 72 Power: 3
Left rear ABS sensor?
1994 MX-6 LS w/ KLZE, chipped ECU, headers, test pipe, Volt muffler, CAI, Outlaw Spacers, Centerforce Stage II clutch, 17" Flik FTD wheels, and black leather interior. http://www.cardomain.com/ride/2616648
1993 Mx-6 LS (RIP) http://www.cardomain.com/ride/2286070
Skanetic is offline   Reply With Quote
Old 5-6-08, 21:38   #13 (permalink)
  Total: 10 Power: 1
HEy
What color is the interior if you still have it? If black how much for the whole car?
Ericsfastmx6 is offline   Reply With Quote
Old 5-8-08, 19:42   #14 (permalink)
  Total: 10 Power: 1
rear glass
n
need rear glass 93 mx6 ls phil seadogpdd1@verizon.net
phil is offline   Reply With Quote
Old 5-16-08, 19:31   #15 (permalink)
  Total: 11 Power: 1
passenger side fender? bumper? what condition? pics maybe? how much shipped to va? thanks!
basketthis69 is offline   Reply With Quote
