Originally Posted by DarkMx-6
What size down pipe does it have?
I also need the 2 part thingy that i cant think of what its called but this thing/
Sorry I ended up not needing this and I didn't have any cash then I should have said something earlier
But this stuff I really need to get because summer is coming and my car will over heat!
1)
Turbo lower brace bolts (4) and flat metal piece (in other words everything but the cast iron piece that bolts into the block.
2)
#1 & #2 Thermoswiches for radator fans (the ones right after the thermastat right before the upper radiator hose) and harness clips if you have it.
3)
passenger side rear plastic piece that goes infront of the wheel well.
4)
drivers side handle inside upper screw cover
all shipped to 76031
edit
Also need the small light bulb that lights up under the dash when you open the door on the drivers side. As many as you have.
