(PA) The Punisher 500+ whp "Part Out" - 22k (aftermarket parts) - Mazda MX-6 Forum
post #1 of 89 (permalink) Old 10-4-12, 13:06 Thread Starter
Quoted: 1 Post(s)
Thumbs up (PA) The Punisher 500+ whp "Part Out" - (more parts, newer pics & lower prices)
All payments will be through PayPal unless local pick up is being made.
All prices include PayPal fees, shipping and handling as well (throughout the US).
PM me for PayPal address.
Suspension:
Power Slot Pro-Series II Rotors - $160
http://i1357.photobucket.com/albums/...9.jpg~original
Feel free to contact me through PM's or on here.
Thanks...
NedPGT is offline
post #2 of 89 (permalink) Old 10-4-12, 13:06 Thread Starter
Quoted: 1 Post(s)
All items listed in this post are sold items...
DEI Turbo Insulation Kits
Cool It Thermo Tec Exhaust Insulating Wrap
Ford Racing Fender Covers (barely used)
Howe Racing Radiator & Radiator Cap
'96 Taillights & GT Reflector
'96 Cargo Net
NGK ZFR7F11 spark plugs
PRD Red Wrapped Spark Plug Wires
255hp Walbro Fuel Pump
Greddy Counter Weight Shift Knob
4 '96 Oxygen Sensors
Greddy (MBXmotorsports) Oil Cap
Goodridge Stainless Steel Clutch Line
Euro Clear Signals
Outlaw Engineering IM & TB Spacers
HKS SSQV Blow Off Valve
Tial 38mm Wastegate .4 bar (not in picture)
Tial 38mm Wastegate 1bar (14.5psi) spring
Flex-A-Lite Dual Slimline Fans 210R (pullers)
Summit Racing Red Battery Relocation Kit
Greddy Profec B Boost Spec II Controller
Snow Performance Stage 2 Kit (WM) + Boost Juice (4 gallons)
Exel Speed 17x7 wheels (2 wheels have barely visible curb rash)
BFGoodrich g-Force Drag Radials 225/45/17 (front) x2
BFGoodrich g-Force T/A KDW NT Tires 225/45/17 (back) x2
PIAA Xtreme White HID Backup (Reverse) Bulbs
PRD Disty Cap w/external coil & additional coil wire (pic of wire taken with rest of PRD wires)
PVC
Key Fob
Mickey Thompsons ET Drag Slicks 24.5/8/15 x2
Garrett GT35R (Turbine: .68mm w/84 trim, Housing .82AR.....Compressor 82mm w/56trim, Housing .70AR)
SS Braided Oil Lines (Feed -4an, drain -10an)
SS Braided Water Cooled Lines For Turbo -6an
Precision 31.5x8x3.5 Intercooler
'96 Distributor w/ 65714 miles on it
Ford Red Painted Cardone Import Rear Calipers
Ford Red Painted Front Calipers
Goodridge braided brake lines (all around)
RR-Racing Poly Engine Mount Inserts (Front & Rear)
RR-Racing Short Throw Shifter w/ shift stabilizer bushings
H&R 15mm Wheel Spacers
Auto Meter Phantom Water Temperature Gauge
140 HO Amp Alternator (less than 500 miles on it)
PA Dual Oil Filter Relocation Kit
Ported KLDE Heads
Interprep 195lbs Valve Springs
MX3 GS Lighten Flywheel 15lbs
Driver & Passenger (cracked on the bottom) window switches
'96 Front Leather Seats
Red Tranny Saver
PLX M-300 Wideband
Ported & Polished Intake Manifold
Throttle Body 67mm
Bored .020 over KLDE Block
Wiseco Pistons/Pauter Rods Combo 8.7 CR
Ross Performance Piston Rings
Toga HP Oil Pump
Pro Topline Thrust Washers
Toga HP Main & Rod Bearings
Tapped Oil Pan
Replacement Head Bolts
"Custom" 5 Speed Transmission (includes all stock parts + 4 items below)
Quaife LSD
Mazda 323 GTX AWD 3rd & 5th gears
Tranny Rebuild Kit
'96 Starter
Duralast CV Axles (driver & passenger) & Intermediate Shaft
Auto Meter Phantom Oil Pressure Gauge w/ green light
Dropzone 1.75" Springs
MBX Ultimate Dual Feed Aeromotive FPR
SPM black Triple A-Pillar Gauge Pod
Spectre Air Filter Breather
2 Carbon Fiber Switches w/ CF plate for cubby hole
Auto Meter Phantom Fuel Pressure Gauge w/ green light
Colt Performance Turbo Cams (INT: 210@.355 lift - 274* advertised duration...EX: 200@.350 lift - 240* advertised duration)
RR-Racing Racing Underdrive Pulley
Modified fuel rails for Nissan 550cc's
Nissan SRDE20 & RB25DET 550cc's Injectors
MSD Coil Blaster 3
Modified Crossmember
Timing Belt Tensioner (less than 10 thousand miles on it)
Traction Bars (brand new)
16" USB to DB9 Cable
6' DB9 to DB9 (male to female) cable
'96 ECU
Carbon Fiber 2 MegaSquirt 3.0 (with lots of features)
Dual DVD In-Dash 7"
Green/Blue Reverse Glow Gauges & '96 PGT Cluster w/ 65714 miles on it
Polished Valve Covers
Tranny Case
'96 Silicone Filled Side Motor Mounts
K&N 4" (inlet size) Air Filter
Auto Meter Phantom 5" Tach Gauge w/ Led
NCR Performance Turbo CatBack
NCR 3" TestPipe
Magnaflow Race Muffler
QTP 3" Electric Cutout
SouthBand DXD-F Clutch (rated up to 685hp)
Sylvania SilverStars Headlights
Ford License Plate Frame
MSD 6A Ignition
Probe Addiction Header Primaries
NCR Performance Turbo Pipes
NCR Intercooler Pipes (Powdercoated by EPC)
NCR 3" Downpipe
NCR Silicone Couplers & Clamps for IC piping
GP Sorensen IAT Sensor
Set of 3 Pulleys (less than 2 thousand miles on them)
AutoVation Racing Pedals (Turbo Charged Design)
5lb fire extinguisher
Auto Meter Phantom Boost/Vacuum Gauge w/ green light
NedPGT is offline
post #3 of 89 (permalink) Old 10-4-12, 13:07 Thread Starter
Quoted: 1 Post(s)
Reserved for any additional information needed.
NedPGT is offline
post #4 of 89 (permalink) Old 10-12-12, 19:00 Thread Starter
Quoted: 1 Post(s)
Yet another update...
Another set of parts is gone for good, but there is still plenty left for everyone.
Every single part is negotiable, so don't be shy with your offers.
NedPGT is offline
post #5 of 89 (permalink) Old 10-25-12, 12:31 Thread Starter
Quoted: 1 Post(s)
One more update...
There is still plenty left for everyone.
Every single part is STILL negotiable, so don't be shy with your offers.
NedPGT is offline
post #6 of 89 (permalink) Old 11-29-12, 21:19 Thread Starter
Quoted: 1 Post(s)
It's time for another update...
Now if you are interested just in block or heads or custom transmission without the clutch & flywheel or just the clutch & flywheel you can buy it separate.
As far as Mickey Thompson ET Drag Slicks goes, now I am selling them without the Mustang rims, since some of you were interested (at some point) just in the slicks.
NedPGT is offline
post #7 of 89 (permalink) Old 12-11-12, 12:12
Will the tranny fit a 2g mx6?
93 Mazda Mx6 klze
biglex is offline
post #8 of 89 (permalink) Old 12-11-12, 14:58 Thread Starter
Quoted: 1 Post(s)
According to this link below it will fit just fine:
http://www.mx6.com/forums/2g-mx6-gen...ssion-mx6.html (Probe V6 Transmission to MX6?)
Let me know if you are interested, I am sure we can work something out.
NedPGT is offline
post #9 of 89 (permalink) Old 12-15-12, 12:17 Thread Starter
Quoted: 1 Post(s)
The block with lots of goodies inside of it has a sale pending... deposit has been received and it should be out of here by Thursday!!! Which means, now you can buy the KLDE heads with the bolts, valve springs and turbo cams separate...
And let's not forget, every part is STILL negotiable, so don't be shy with your offers.
NedPGT is offline
post #10 of 89 (permalink) Old 12-21-12, 1:48 Thread Starter
Quoted: 1 Post(s)
Latest & Greatest...
A few more parts added, newer pics for some of the parts and some prices have been lowered...
Just for these upcoming holidays, for every listed part you will get 10% off, but if you buy multiple parts you may get a sweater deal, so let's get this thing rolling!
NedPGT is offline
post #11 of 89 (permalink) Old 12-27-12, 9:11
I pmed your bro.
93 Mazda Mx6 klze
biglex is offline
post #12 of 89 (permalink) Old 12-27-12, 12:47 Thread Starter
Quoted: 1 Post(s)
I pmed your bro.
Check your inbox for a better deal than 10% I was offering in the first place and lets keep these messages private and not on visitor's page since I did not see yours until you posted in this thread.
NedPGT is offline
post #13 of 89 (permalink) Old 1-3-13, 19:38 Thread Starter
Quoted: 1 Post(s)
Just another update...
I will leave the 10% off discount for a few more days, which still applies to every listed part and if you buy multiple items you may get even better deal...
NedPGT is offline
post #14 of 89 (permalink) Old 1-8-13, 23:31 Thread Starter
Quoted: 1 Post(s)
Distributor, front/rear calipers & braided lines sold and shipped. Thanks to Midnight ProbeGT & The Red Demon!
NedPGT is offline
post #15 of 89 (permalink) Old 1-13-13, 23:32 Thread Starter
Quoted: 1 Post(s)
Sale pending on: Ported & Polished Intake Manifold and Throttle Body 67mm...
NedPGT is offline
