Closed Thread
Old 9-11-05, 22:09   #1 (permalink)
FS Wilwood Big Brake Kit
Kit uses Wilwood 4 piston calipers, RX7 rotors, and a custom relocation bracket. Sells new for $750, I need $450. I used it for less than 5k miles, it looks great and works very well. This is an excellent, affordable kit. Affordable in original price and if you ever need new rotors or pads they're also readily available and much cheaper than 2 piece rotors. This is one of my favorite mods, but I am parting out my car and I can sell this and still drive it for a while. PIC
AaronD81 is offline
Old 9-12-05, 0:27   #2 (permalink)
  Total: 355 Power: 5
esembe's Avatar
Sweet setup, someone jump on this!
esembe is offline
Old 9-12-05, 10:43   #3 (permalink)
  Total: 476 Power: 0
Heather's Avatar
I want them, but wont have the money for a month...if you still have them then, I will get them....
Heather
Heather is offline
Old 9-12-05, 13:33   #4 (permalink)
  Total: 42 Power: 5
Do you have to run 18's to clear the caliper on this kit?
1993 Mazda Mx6 LS, MTX! KLZE, black on black, 245/45/17's, stage 2 clutch, fidanza flywheel, borla, j-spec's with black bezel, Ground controls, GR2's,
UP COMING: Rollcage (hopefully), hid's with valeo projectors, handling components.
import_killer is offline
Old 9-12-05, 13:49   #5 (permalink)
Nope, 16's will clear. I had 16" Rota SLipstreams and it looked really mean. The brakes filled the wheels completely.
AaronD81 is offline
Old 9-12-05, 14:30   #6 (permalink)
  Total: 75 Power: 5
if i had the money this would be sold now
94 Black Mx6 Ls ZE 5spd - 65mm TB, 9lb flywheel, cai, headers, highflow cat, borla catback, eibach springs, kyb gr-2 http://www.cardomain.com/memberpage/786568
http://www.myspace.com/unkiedavemx6 Can someone please tell me what was done to this front end??? http://www.youtube.com/watch?v=sOLq6...eature=related
unkiedave is offline
Old 9-12-05, 22:35   #7 (permalink)
  Total: 51 Power: 5
Got a dimension from center to the point furthest out on the caliper?
1993 626 ES: Eibachs, Tokico Blues, PT 17.5mm sway bar, AWR trailing links, 15x7 ATS Comp Lites (13.5 lb), PRM, 65mm TB, Borla, RR-Racing inserts, custom short throw shifter, JDM 626 headlights.
1994 Miata R-package: TEIN Flex, Hard Dog Hardcore, 13x7 Panasport ULs.
jduffett is offline
Old 9-12-05, 22:47   #8 (permalink)
  Total: 304 Power: 5
hughes46's Avatar
Can this setup be used on the rear? If so, I would be interested.
hughes46 is offline
Old 9-13-05, 3:49   #9 (permalink)
  Total: 129 Power: 5
I will take it What is your paypal address?
96 merlot mica M-edition121k miles new toy!
95 Viper Blue Mazda Mx-6 M62 SC'ed and MS'ed KLZE 85k on body and motor.
89 White mx6 gt- 90k crashed*RIP* 88 mx6 gt blown headgasket- *RIP
88 mx6 gt 150k new motor soon 1991 Mazda Miata
Chunchoy14 is offline
Old 9-13-05, 4:14   #10 (permalink)
  Total: 129 Power: 5
btw, it comes with everything below correct? E-racer kit
-2 billet aluminum, anodized 4-piston calipers
-2 rotors, drilled, slotted, and plated
- 2 caliper brackets
-2 brake line fittings
-4 x caliper nuts and bolts (black), grade-10
-20 x high modulus washers (gold)
-4 x hub nuts and bolts (gold), grade-10
-8 x hub washers (silver)
Old 9-14-05, 0:00   #11 (permalink)
  Total: 120 Power: 5
t_dubb's Avatar
thiss is a steal people... trust me.. wilwood is the way to go...(sheesh, mine cost 1200)
94 KLZE JSpecs,TC Sportline BC Kit,OEM CF hood,CF mirrors HotShot headers,CAI,AEM FPR,Oil Cooler,Slimline Fans,E.L.PROTO ECU,Apex S-AFC,Autometer oil,water temp,A/F guages,Greddy SP2(black),Test Pipe,CM stg III, Fidanza FW, Walbro 190,17" Rota Actions,Neo Gen tires,Willwood Big Brake Kit (front), Brembos (rear),SS brake lines,Eibach Pro Kit,Tokico Blues, Mazdaspeed rear swaybar,RRE RSTB, MOMO Race steering wheel.
t_dubb is offline
Old 9-14-05, 9:56   #12 (permalink)
Sale pending. Thanks for your interest.
AaronD81 is offline
Old 9-14-05, 12:44   #13 (permalink)
  Total: 5000 Power: 6
Goatcrapp's Avatar
Mike - it can certainly be used in the rear, but would need some custom bracketry.. the problem with these calipers inthe rear is the complete lack of ebrake functionality.. there's nothing to connect it to.
also - with the deep dished rims you have, it may not clear the caliper.. i know the wilwoods are a bit smaller than the outlaws i have, but i had possibly the same rims in 17x7 (what are they anyway?) and they simply wouldn't clear because of the spokes being set in deeper, from the lip. most rims should fit however.. just not something with a dished design, or wide lip, unless you use a thick (hubcentric with lugs) spacer
Goatcrapp is offline
Old 7-27-08, 20:53   #14 (permalink)
Im stupid and didnt look at the date
Regards,
Andre S
93 Mazda 626 - Heavily modified - Cross Pollinated - Work in Progress
--------------------------My Build Page--------------------------
RoadRage is offline
Old 7-27-08, 21:45   #15 (permalink)
  Total: 366 Power: 5
wow... no joke!
~ChiPoC~
monoxidechild is offline
Closed Thread
