Kit is Brand new- Never used.... Upgraded a few things- Asking $2200 plus shipping- which is well below what I paid for it.
It started out as an AIM Kit III FBSS (Front, Back, Side, Side), but i have changed a few things, so I'll include everything.
Specs are
5gal. Chrome Tank, with 4 1/2" outlet ports
(2) DC2000 1/4 hp Compressors
Steel Braided lead lines into the tank
1 way check valve for line in
(8) Big Red 1/2" Fast Valves (Dump/Fill in less than .5 sec) on blocks (2 blocks, 4 valves on each)
Fixed 110psi on/145 psi off Pressure switch
Water Seperator
(5) Pressure senders, Measures 4 corners plus tank pressure
Digital Screen, Displays 4 corner pressures, tank pressure, along with warnings for low/high pressures
(4) Struts with bags- also have 10 pos. adjustable valving to control dampening (For ride quality- Almost like tokico illuminas, only 10 pos. instead of 5)
(4) Brand new Monroe Strut Mounts
10 Switch box Clear
1/2" Nylon Air line for feed to struts
1/4" Nylon line for pressure senders
Wiring Kit- 8 guage power, 18 guage valve and switch line
Solenoid For power to compressors (Upgraded from Relay- Solenoid is just a Heavy duty Relay
A Bunch of fittings to make everything all nice and clean looking.
Also included are the original parts which i had upgraded from- 3 gal. Aluminum tank, adjustable pressure switch, 4 1-2 Switchs for dump/fill, Relay, misc fittings
Right now the setup is mounted on a plywood platform, and can actually be dropped right in the car and be hooked up. I can get some pics of it if you like. Everything is new, All I did was hook it up outside of the car to make sure it built pressure. There might be more that I'm forgetting, If i think of anything I'll put it up
Adam
Here are 2 pics of the board... The board is now cut to size, and the pressure switch and tank pressure sender are mounted in the port right below the line in.
