I have 2- 19mm Rear sway Bars, they are made in solid spring steel and a direct replacement on the 2g mx6. You WILL need larger bushings to use this bar. I recommend buying the poly bushings off AWR, or Locally. Ive heard that the stock bushings can be bored out to 19mm (3/4) but ive never tried it.
Asking $80 shipped each. They are in a Black Finish
