Old 10-31-05, 12:02   #46 (permalink)
  Total: 1166 Power: 5
Graham_A_M's Avatar
Originally Posted by Panther37
Why isn't this a sticky?
I left my sunroof open and now my driver's seat has "hard spots." They are not completly ridgid as if I spilled glue but they are not right. How should I fix this?
You tell me why this isn't a sticky.. I wrote this up for everybodies benefit.. and PM'ed Goat about making this a sticky numerous times.. and STILL its not a sticky.. whats up with that? Its helped out SO many people..
Here is the best stuff on the market... its that actual "Prime" goop that I used in the tutorial...
http://www.nvo.com/prodcarcare/pages...catuid%3D10139
It comes in a huge 3.8 liter jug... so its good for at least 15 applications for either your car or your friends and families...
please remember that this cleaning and application process should be done (ideally) at least every season.. where as 4 months (or ever more) per year are the best... once or twice a year is not going to prevent any cracks.. since thats AMPLE time for your seats to dry out in-between applications.
Basically.. if you really want your cars seats to stay mint.. do this once a month.. even then you'd still be amazed at how dirty your drivers seat will absorb.. its quite nasty really.
Panther.. to answer your question.. I've never dealt with "hard spots" on leather seats per se.. but since your from Hawaii.. I'm guessing that was from the heat of the sun one day.
One night .. when the car will be sitting for a day or so.. or at least 12 hours.. spread a (cookie sized) gob of that prime stuff on your seats hard spots.. over the night it will absorb mostly into the seat.. that should soften them up.. at that point do the whole clean and application process again then that should clear it up.. if not PM me.. and I'll ask this re-nowned detailer that I used to learn from back in the day when I used to detail.. of what he'd do.. it shouldn't be too hard.
If you dont want to buy that "prime" goop.. then buy some kind of creme with "lanolin oil" in it.. since thats the key right there.. its the lanolin oil that does the trick
Originally Posted by Speedbumpthedog View Post
i also [shizzle] all over my hand trying to light a fart on fire in front of like 30 people at a party. that SUCKED. ruined my favorite lighter and my watch.
'04 BMW Z4 3.0I, SMG 6speed w/triptronic, ///M sport suspension option.
Graham_A_M is offline   Reply With Quote
Old 10-31-05, 12:14   #47 (permalink)
Graham_A_M's Avatar
Oh yeah.. either this
http://www.nvo.com/prodcarcare/pages...catuid%3D10043
or this
are the two best waxes I've ever used.. they are a ONE STEP process (just wash your car really well and wax away with a good applicator pad such as this
http://www.nvo.com/prodcarcare/pages...catuid%3D10030
and your good to go.. just wipe on and wipe off with a CLEAN terry cloth (or beach towel if you dont have one)
when applying the wax.. leave the car a little bit wet every here and there.. whereas dont dry off the car completely.. if the app. pad is wet... the wax will go on way smoother...
and then WAIT for the wax to COMPLETELY dry before you wipe it off.. then it'll of settled into the pores of the paint.. besides to wipe off wet wax is a distastor... wait until it dries which will typically take 20 minutes or so.. best to wax the car in the sun.
hope this helps..
BTW.. lots more posts to come about car care.
Old 10-31-05, 12:31   #48 (permalink)
  Total: 1613 Power: 5
Fastest95PGT's Avatar
Ordered.
The dishwashing detergent / water mix is good for prep cleaning right?
PARTING A LOT OF 2g STUFF
Old 10-31-05, 13:25   #49 (permalink)
Graham_A_M's Avatar
I'd avoid the dishwashing liquid soap all together.. its really not designed for this at all.. you can if you want.. but Mr. Clean or Pine sol is way better.. but sure it would work if you dont have the latter.
Make sure its mild cleaner.. (about as strong as you'd normally use on your hands) you want the actual scrubbing to get the dirt out of the pores.. not the chemicals... too strong chemicals will actually wipe the dye right out of the seats.
Old 10-31-05, 13:29   #50 (permalink)
Consider it done.
Are there different strengths of either of those? My car's gonna be so pine fresh after.
Old 10-31-05, 13:58   #51 (permalink)
Graham_A_M's Avatar
Dishwashing soap is only designed for dishes.. and food.. nothing else.. you can use for otherthings (such as this and cleaning floors or whatever else) but it wasn't designed for it.. however Pine Sol and Mr. Clean were designed for general cleaning for a really wide variety of stuff: such as this and everything else. It'll just do a better job.. and it won't foam up when you scrub it.. which helps!
Also any cleaner from wally's world will work too.. like "Spray nine" or whatever.. if you have any questions.. just PM me..
AVOID BATHROOM CLEANERS!!!!!!!!
Old 10-31-05, 18:00   #52 (permalink)
The Mod With the Mostest.
  Total: 1076 Power: 5
Panther37's Avatar
I honestly think it's from water. During the day the car is parked under a carport. I work at night. This happened like a day after I left the sunroof open and had to wipe the inch of water from the seat. I'm trying to find something that is good for one or two applications because I'll be moving after that. I doubt the movers here will ship it.
Old 11-2-05, 1:57   #53 (permalink)
Graham_A_M's Avatar
And the funny part is... its still not a sticky... whats going on? at least in the 2gen projects would be good.
Old 11-2-05, 10:57   #54 (permalink)
  Total: 223 Power: 5
Keegan's Avatar
Come on mods. What do we have to do to get Graham_A_M's post a sticky?
Keegan is offline   Reply With Quote
Old 11-2-05, 16:07   #55 (permalink)
  Total: 953 Power: 5
It should be a thread in 2G Projects, not a sticky.
Old 11-2-05, 17:19   #56 (permalink)
  Total: 140 Power: 5
Why? It's not 2G specific at all... it applies to all leather seats (or at least that's how I see it)
Walkertexas69 is offline   Reply With Quote
Old 11-2-05, 18:23   #57 (permalink)
  Total: 34 Power: 5
what can you use to give the seats a darker tone?
rock is offline   Reply With Quote
Old 11-2-05, 18:50   #58 (permalink)
  Total: 1504 Power: 5
Stealth's Avatar
You can have them dyed, My dad just got his tan leather coat dyed black, and i was sceptical at first but it looks AWESOME
Project Silo
CF Dash with TV CHEAP
Old 11-7-05, 13:09   #59 (permalink)
Originally Posted by Fastest95PGT
Ordered.
I must say that I am disappointed with the linked site's sales customer service so far. I have still yet to recieve any sort of shipping confirmation.
I have sent two e-mails requesting it with no response. Today I finally called and it went direct to voicemail. I left a voicemail (about 3 hours ago) and no call back yet.
Old 11-15-05, 9:41   #60 (permalink)
Finally got the gallon (of course, way past late now considering MM8 is over with) but I'm looking forward to doing this and seeing how it goes. I'll try to remember to take some before & after pictures to contribute to the thread.
