Resetting oil change required light? (various models)
hey guys im hoping someone can at least point me in the right direction. im looking to find out if there is a chart (or information where i can make my own chart) with the procedure on how to reset the change engine oil light (not check engine) on cars... i need it for all models chevy, ford, dodge, mazda, etc... i work for a oil and lube place and its always a struggle to figure out how to shut those things off... if there is place that would tell me that would be great. Karma will be dispensed accordingly
If you want something you have never had, you have to do things you have never done - Paul Pollard
#6 (permalink) |
... walmart Tire Lube Express
most of the guys there are old v8 guys that dont work with computers. technically resetting the oil life light or whatever is "not a service that walmart offers" (from my manager) but im just trying to find out so i have a few less customers yelling at me![]() and some i have looked through the owners manual and there is nothing in there... no procedure hell i looked in one for the recommended oil and it said "Use Recommended Oil Only" ...... went page by page through the manual and so did the customer (cause he was pissing a brick about the weight of the oil) and nothing |
#7 (permalink) |
All aboard the B& V&
more than likely it requires an OBDII reader than can reset the change oil/oil life code. You can pick those up at Kragen probably, for under $70.
#9 (permalink) |
Really? interesting. glad I don't have a care like that. crap like that would drive me nuts.
resetting oil change notification - Google Search Seems there are plenty of ways... |
#10 (permalink) |
there isn't ALWAYS a trick defiler.
the onyl way to reset it on a many newer model hondas, for instance.. is an obd-II scanner |
[x]MX6 #2. SOLD [x]Toyota Paseo. 42MPG. [x]5.9 Jeep. #1's tow vehicle. Still faster than most KL's.//Modifications List |
#12 (permalink) |
2005 Chev Trailblazer LT
1) Turn Ignition to RUN with engine off 2) Fully press and release the accelerator pedal slowly 3 times within 5 seconds 3) Turn the key to LOCK If it does not work, repeat 1 - 3 again till it does. Right from the owners manual. If the vehicle has a Drivers Information Center. Screen under the Speed. Press the (Gas pump symbol) select the oil life screen, then press and hold the select button (back arrow on steering wheel) for 5 seconds the display then will read (Oil Life Reset) Last edited by John_Shea : 8-7-08 at 16:32. |
"Racing Honda's is much like the Special Olympics, Even if you win, you’re still retarded"
#14 (permalink) | |
BUT.. I'm almost positive newer veedubs need a scanner. |
When I missed our Anniversary, I figured I'd be at her Birthday.
When I missed her Birthday, I figured I'd see her on Christmas. When I missed her on Christmas, she understood my priorities. When Paintball Comes First, Nothing Comes Second. |
#15 (permalink) |
With a Pontiac G5, you can reset the oil life meter through the Driver Information Center. You scroll to the Oil Life screen and hold the reset button, it'll reset.
For a Silverado 2500HD (Duramax) you go through the same procedure as posted above for the Trailblazer. For a Malibu, I can probably look it up in my mom's owner's manual... |
90 MX-6 LX - fresh engine - GT digital cluster - soon to have two-tone interior - pictures here
