Car bolt pattern and center bore list - Mazda MX6 Forums: MX6 Forum
Old 12-22-09, 21:54   #1 (permalink)
  Total: 104 Power: 5
found this and thought id share with the community
http://adaptitusa.com/referencebook.htm
When you plan for success you don't need a plan B - Jason Mohring
Real cars like real men have sticks... - Kevin Bond
Bought at 106,000 and lived to 189,000+ Miles! was killed 5/2010
Looby is offline   Reply With Quote
Old 12-23-09, 17:17   #2 (permalink)
  Total: 1142 Power: 5
I4MX6's Avatar
I like it! Thread stuck!
-Matt-
Old 1-6-13, 6:34   #3 (permalink)
  Total: 10 Power: 0
Does the center bore only affect the original wheels? Do I have to check the center bore on the after market rims when I look for a second hand one?
mike33 is offline   Reply With Quote
Old 1-6-13, 20:05   #4 (permalink)
  Total: 1735 Power: 5
Fastest95PGT's Avatar
The center bore on the new rims would have to be as large or larger than the stock center bore.
If smaller, the wheel would have a space between it and the rotor and be very unsafe to drive.
PARTING A LOT OF 2g and 1g STUFF
FS: Borla for sale.
FS: Clear headlight covers, headlight, fog, tail, gauge cluster
90 PGT MTX with 97k original miles!
Old 1-16-13, 5:35   #5 (permalink)
  Total: 433 Power: 5
PaulG's Avatar
To add to what Fastest said, if the new wheel has a larger bore than the original wheel, a hubcentric ring (google it) is used to make up the difference so that the new wheel mounts as snugly as the original.
1997 MX-6 LS
Old 1-20-13, 8:38   #6 (permalink)
As long as the lug holes are tapered, I think the lugs (assuming also tapered) would center the wheel enough on the hub.
FS: Borla for sale.
Old 1-21-13, 5:24   #7 (permalink)
  Total: 433 Power: 5
PaulG's Avatar
That's true, but hub rings are usually used to make up the difference.
1997 MX-6 LS
