#31 (permalink) | |
89MX6 GT 4WS - Not stock... 135whp/170wtq@7PSI on blown VJ11
#33 (permalink) | ||
Back to the Booster
i think his point was more for track only cars. ones that are trailered to the track, make a few runs, then go back on the trailer. |
My Garage
1987 MX-7 Worklog 1988 MX6 GT 14.8 @ 95mph 11psi on stock turbo --- motor going into the RX-7 1988 MX6 GT --- The DD - Stock + HKS SSQV |
#34 (permalink) |
Its a requirement to have an alternator in SCCA racing.
Maybe that's just in my category, tho. I dont see any way to get out of using an alternator, because your only replacement is batteries, and the added weight negates the couple of HP youd gain. |
4WS.ORG (4 wheel steering) \--\ l /--/ U-turn in the driveway!
#35 (permalink) |
Back to the Booster
lol. i meant drag strip. not road course. all you'd need is to maybe keep a low level charger on the car when its not running.
My Garage
#37 (permalink) |
still got no answer as to what the weight differential would be?
KITTED 92 MX6 GT<-CLICK HERE Quote: Originally Posted by SD6 "A crackpipe is what you hit." |
#38 (permalink) | |
El...
did you post this and then realize it was a dumb question since the water pump runs off the timing belt pulley and deleted it? Quote:
#42 (permalink) |
By the way, I just did some researching and I dont see that it is that important to balance an aluminum pulley after lathing it as long as the lathe has a very low tolerance, like .002" or less, and the lathe is turning at 2000 rpm or more. The act of lathing the aluminum balances it. BUT if you go and bore holes in it to lighten it, THEN you have to rebalance it, which I guess you cant do on a lathe. I really need to do some more research on this... I will call some places.
BUT, I did find out more about anodizing. The anodizing process strengthens the aluminum and is pretty important for a billet aluminum pulley. We wouldnt want the pulley to come apart. SO I think its pretty important to get them anodized regardless of color. |
#43 (permalink) | ||
IIRC Sick has talked about a shop that does balancing before. Maybe he could chime in with any info he has... Quote:
#45 (permalink) |
Well I just realized 2 things, that the 6 holes are not even and there is a notch so it will be unbalanced by design, and will need to be balanced. There is a shop here that can do it if the center hols is 1" in diameter. Can someone go grab a crank pulley and measure it real quick?
