#31 (permalink) | ||
There is more work to do on the front valve cover (like polishing the mazda symbol and so forth). |
#33 (permalink) |
If you were closer then I'd probably consider it. But it will sadly cost just as much for me to have it done by you as it would to have it done locally, especially after shipping. But damn thats a good price because I'm going to be paying $100 to have both mine done locally in wrinkle black.
-Matt-
1994 Mazda MX6 LS, Infiniti G35 HID conversion, 2.5" Magnaflow cat-back, 3" CAI, 16x8" FD RX7 wheels, LEDA Custom True Coilovers, shaved body and full repaint, Genuine Mazdaspeed Kit, '03 Protege rear caliper conversion, and much, much more... |
#36 (permalink) |
i'm never in this forum...
I'd be interested. I have a spare front VC that I've been wanting to have powdercoated... since you're local, I'm definitely interested. As far as color, I was hoping for a gold / copper vein.
I dunno which color to go with though. It would not be hard to convince me to get an matching IM of course... |
#37 (permalink) | |
and my VC would be a F2T VC, but $30 isnt bad. what brand powder you running so i can get a custom color and send it to you with my VC. |
#38 (permalink) |
Powder coating a rim in a tight often is never a good idea. Poor air circulation will get uneven results. This is why you should use a convection oven with plenty of space to circulate air around the item.
Word of warning to anyone looking to PC flat surfaces (ie: valve covers, heat shields, etc). Even though Justin is suggesting media blasting, any pitting which might currently be present on the item will still be there after PC'ing. So if you use a plain gloss color, it can tend to be noticable if you're picky. I had my VCs done as gloss black years ago and a spot which wasn't noticable on the front corner was horribly exposed once the grease was removed from being blasted. I confirmed the spot was not caused by the blasting when I looked at my "before" pictures. This being said, you don't have to make them spotless before sending them to the PC oven, but I would suggest you definitely hit the flast surfaces with some sand paper to make sure you know what you're dealing with for smoothness. |
PARTING A LOT OF 2g STUFF
