Go Back   Mazda MX6 Forums: MX6 Forum > Mazda Family > Mazda6 General
Old 11-22-08, 17:16   #46 (permalink)
  Total: 10 Power: 2
Love the car wish i had one like yours. and keep up the good work!!
jmac is offline   Reply With Quote
Old 11-24-08, 22:49   #47 (permalink)
  Total: 312 Power: 5
That is one Sick Six, ha ha i made a funney. Great work though. Thant is one of the better Mazda6's i have seen on this forum. I am really starting to like Keep up all the hard work man and reap the bennifits of owning a sweet ride.
Old 11-26-08, 0:53   #48 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
So I ended up blowing my amp today on the way to Taco Bell. The fuse literally blew into pieces, pulled the access panel off, and instantly smelled burning electronics, and noticed that 1 of the MOSFETs was charred. So i'm going to look into seeing what kind of warranty it has before I try to replace it.
Eaton? - AWR - Mazdaspeed Acc. - Injen - CP-E - Greddy - ProSport - Corksport - Falken - Voodoo - MTX - Medieval Motorsports - Heronew - Apexcone - OBX
Old 3-19-09, 9:21   #49 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
It's been a while since I updated this thread, but I've got some news.
I got a set of 6000k 55w HIDs for Christmas, I got a set of 18x7.5" Hyper silver 5ZR's (which I might have a buyer for), a set of black JDM tail lights
I've bought a couple other things that are waiting to be installed. An Acura RDX shorty antenna, OBX shorty headers, AWR transmission mount, o2 sensor simulators,
Old 3-25-09, 21:03   #50 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
My AWR Upper Transmission mount when in last night, and Jesus is that thing loud. It does the job of keeping the drivetrain from moving, but I hope it breaks in quickly.
Old 3-29-09, 16:09   #51 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
I found the torque Specs for my motor mount, and when I tried to torque them down, one of them snapped. So after using an easy out, buying a new bolt, and torquing them to spec, the motor mount is a lot quieter and I no longer have any wheel hop.
I dropped my headers off to get the cracked collector rewelded, and I will hopefully have them repaired for next to nothing.
I also talked to a friend of mine who owns a VW/Audi tuner shop about getting my rod and main bearings swapped out this summer while my motor is out for a series of part installations.
Old 3-29-09, 21:25   #52 (permalink)
  Total: 348 Power: 5
Mazda4ever's Avatar
wow neal, sounds like nothing but progress progress progress! im almost tempted to ditch the rotas for some stock speed6 rims
Mazda4ever is offline   Reply With Quote
Old 3-30-09, 9:13   #53 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
Originally Posted by Mazda4ever View Post
wow Neal, sounds like nothing but progress progress progress! I'm almost tempted to ditch the rotas for some stock speed6 rims
Yeah, she will finally start coming together. I have those lightwieght pulley's that have been sitting around for like 2 years that are going on. Front sway bar, oil filter relocation, and hopefully powdercoating my valve covers will all be taken care of at the same time.
Why would you ditch the rotas? I think they look great.
Old 3-31-09, 19:35   #54 (permalink)
  Total: 348 Power: 5
Mazda4ever's Avatar
damn cheap things, hyper black is black with overlaid silver and the silver is already chipping/flaking off all over on 2 of the rims quite frustrating since i paid 1500 for em less than a year ago
Old 5-20-09, 10:49   #55 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
Finally started getting my headers ready for install. Got the cracked flange welded, got almost all the hardware I need, and I finally got them wrapped. All I need to do now is to get some gaskets and they'll be ready to pop in.
Old 5-20-09, 23:20   #56 (permalink)
  Total: 348 Power: 5
Mazda4ever's Avatar
Good luck dude! let me know how they hold up!
Old 6-17-09, 21:56   #57 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
So after finally receiving 99% of the parts I needed (DAMN YOU WRONG SIZE GASKETS!) I chose today to go ahead and install my OBX Headers, along with some H3 HIDs, (hopefully) most of my lightweight pulleys, new AWR Tranny mount bushings, new spark plugs, and a dual oil filter relocation kit.
Don't mind that throttle body, it's just been stripped down and had the castings filed down in preparation for powdercoat.
First things first, I got the car in the air to do any of the work. Then I pulled of the front bumper, headlights, and foam bumper support. I removed the foam bumper support in order to get myself a couple of extra inches closer to the work in the engine bay. Then I went ahead and pulled off my intake, battery and tray, intake manifold, map sensor, and EGR bracketry.
BTW, that's a brand new "Laboratory Oven" that I got from Good Will for $15. It's good for 430* F, so I'm debating keeping it of selling it. I may borrow a friends PC gun first and see if I'm any good at it before I throw $100 at a PC Gun.
Disconnected all 4 o2 sensor harnesses. In the front it's the large 4 wire Grey and Black connectors, which are pretty easy to identify. The rear was slightly trickier. There are 4 harnesses in a very small area and it's hard to tell what is what, but let me clear that up for anyone else who is thinking about doing this. The passenger side front (which should have a green heat shrink on it), and drivers side rear (which is slightly hidden) are the 2 o2 sensor connections. The driver's side front connector is only 2 wires, and goes to the knock sensor on the back of the block. The other connector is only 1 wire, and I have yet to trace it's final destination.
Then I got down to the nitty-gritty work. Removed the y-pipe first, then the main cat for the front bank, then the dual flex section (without dropping the subframe I may add), all in rapid succession. Which 2 lizards promptly started humping on.
Then I fought the small spaces and a couple arm/hand cramps to get the front collector off. The accessory belt came off after some fighting, but it had to happen in order to get the alternator off. Got the alternator out, and a small piece of advice for those removing the alternator, the plastic cap that shields the wire is actually clipped to the alternator itself, you must insert a flat head screwdriver into the plastic cap, and pry it away in order to get the power wire off. After that I finished removing the rear exhaust manifold, which was considerably easier than the front.
So now here are some random shots of an exhaust manifold-less 6s.
Taken from the front of the catback.
Hopefully I can finish up the installation tomorrow. I was supposed to have help from my friend who is a certified mechanic, but he got called into work. So down a man, taking my time, and having to run a bunch of errands, I'd say I probably got all this done in about 4 hours of true labor. So if I put my nose to the grindstone tomorrow, I may just get this knocked out before 2 friends show up after 5.
Here's what is on the list so far.
* Drain Oil.
* Wire up o2 simulator.
* Swap tranny mount bushings.
* Buy o2 sensor socket and remove o2 sensors from OEM pipes.
* Shorten 3 or so exhaust manifold studs to clear the headers.
* Install o2 sensors into collectors
* Install collectors.
* Install new spark plugs.
* Install o2 simulator.
* Reinstall intake manifold.
* Hook up EGR.
* Install Oil filter relocation kit.
* Add oil, check for leaks, and figure out require oil amount.
* Install lightweight alternator pulley.
* Install alternator and belt.
* Install Flex pipe section.
* Install front connector pipe.
* Fabricate hanger for front connector pipe.
* Install upper fog HIDs.
* Reinstall intake.
* Reinstall headlights, bumpers, fender liner, and wheel.
* Reinstall battery tray and battery.
* Double check all connections, and hose fittings.
* Go for a spin!
If I get lucky, I'm going to run to my friends shop and have the cat in the y-pipe cut out and replaced with a section of pipe. If he's feeling generous, I'm going to see if he'll make a mandrel y-pipe for me. MAYBE I'll get around to getting the other 2 pulleys installed, but that's much less important than getting the car running again.
Old 6-19-09, 16:44   #58 (permalink)
  Total: 348 Power: 5
Mazda4ever's Avatar
copy and paste KING
Old 6-20-09, 20:23   #59 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
I am indeed.
BTW, Headers are installed, and everything is great except for the fact that one of my flex-pipes is leaking, and as such I sound like a geo with no exhaust on it. Once that is repaired, I should be much happier.
Old 12-19-09, 13:51   #60 (permalink)
  Total: 57 Power: 5
ive finally seen your car nealio, when are you puttin an exhaust on the 6 marcus?
95 pgt klze,pacesetter catback exhaust, cold air intake, tokico blues coilovers 1"- 1 1/2" drop, hei mod
R.I.P 90 mx6 gt , intake , boost controller, zombiess chip, lx pistons 12 psi
http://www.cardomain.com/id/90turbomx6
swamper edition is offline   Reply With Quote
