13.7@98 N/A Mx-6 VID inside! - Mazda MX6 Forums: MX6 Forum
Go Back   Mazda MX6 Forums: MX6 Forum > Open Forums > Gallery > Movie Gallery
Old 2-21-09, 1:01   #1 (permalink)
  Total: 28 Power: 5
So went out to the track tonight with the DD Mx-6 b/c the probe is down yet again. Turned out pretty good.
This is what i ran plus some other 13sec passes.
Car:
97 mx6 KLZE swap full leather interior with ice cold AC.
Mods:
1. KLZE
2. MS system
3. Mandrel bent 2.5" piping to a Borla muffler
4. Pacesetter headers
5. Cold Air intake
6. Fadanza 9lb flywheel
7. RR racing inserts
8. RR racing UD pully
9. 65mm TB
10. Clutch Masters stage 1 kit
11. Nitto 555r drags
12. FD rx7 rims
Slip numbers
97 Mx6 5speed: KLZE - Pacesetter headers - Prealude cold air intake - B&M sts - v3 MS - Fadanza 9lb flywheel - RR racing inserts - PMO traction bars - stage 1 clutch master - Borla exhuast - cat delete - FD wheels with light weight lugs -96 PGT-t 13.2@104 on 5lbs w/drags pump gas - 12.2@119 on 14lbs - Both cars tuned by Radar with his built MS systems! Get yours today!
KL-Motor-Sports is offline   Reply With Quote
Old 2-21-09, 8:24   #2 (permalink)
  Total: 211 Power: 5
The_Evil_Demon's Avatar
I wish i lived down there. I'd be at the track with ya What is the estimated cost to get a 2nd gen to run that? And What about if One stripped out some weight?
2001 Ford CVPI New Engine, 2000 Taurus SES New Engine, 1995 Mx6 Ls New engine, Headers & 2.5" exhaust, CAI, 255# Fuel Pump,ksports
Old 2-21-09, 9:43   #3 (permalink)
  Total: 141 Power: 5
Dude....youre the [fizzle]ing man. Props
Acquire currency
weaksauce is offline   Reply With Quote
Old 2-21-09, 15:38   #4 (permalink)
  Total: 28 Power: 5
IDK man if you bought everything new it be close to 3000.00 bucks but if you shopped and bought used stuff then you could do it for less. The most costly iteams are going to be KLZE motor and megasquirt. Tunning and stuff like that. If you get a custom exhuast like i did that cost a good chunk of change.
Old 2-21-09, 16:14   #5 (permalink)
  Total: 181 Power: 5
That very impressive! I bet the nissan guy was "whaaaaaaa....."
unamedplaya87 is offline   Reply With Quote
Old 2-21-09, 16:20   #6 (permalink)
  Total: 47 Power: 5
MazdaMan88's Avatar
Good run, man. Is that your best time in that car?
MazdaMan88 is offline   Reply With Quote
Old 2-21-09, 17:07   #7 (permalink)
  Total: 28 Power: 5
Yeah so far it is. I still need to fix a few things to be running perfect.
Im being told on PT that this is the best time anyone has gotten with a stock block motor n/a. meaning stock cams,pistons,and rods. plus full interior. The only weight reduction is the FDs
Old 2-24-09, 23:04   #8 (permalink)
  Total: 19 Power: 5
Very nice run. so your running these with your vris tied open?
-94 mx6 ls
-88 mx6 gt
laosracer12 is offline   Reply With Quote
Old 2-26-09, 20:30   #9 (permalink)
  Total: 28 Power: 5
Yeah for some reson when the vris kicks in it makes the car sputter. Its somthing to do with the ms. So i tied them open and i started running much better. I still would like to use the vris so my short times could get better and i can get some top end. I think once i get them working i can get some better times.
Old 2-27-09, 21:35   #10 (permalink)
  Total: 19 Power: 5
yeah, i was reading the forums about your 1/4 time at probetalk, put some slicks on there with weight reduction, you can hit mid to low 13s.
-94 mx6 ls
-88 mx6 gt
Old 3-14-09, 0:17   #11 (permalink)
  Total: 28 Power: 5
I wanna try getting 13.5 on DOT tires 1st. im only 1.8 60ft away from that
Old 3-14-09, 0:20   #12 (permalink)
  Total: 715 Power: 5
Would you be willing to send me your MS File?
boarding with my wiener out
Old 3-14-09, 22:15   #13 (permalink)
  Total: 10 Power: 0
sick run
cfactor is offline   Reply With Quote
Old 3-15-09, 12:20   #14 (permalink)
  Total: 28 Power: 5
I would but I dont know how? Radar tunes my car and i never see the ms again. Next time am at Radars house ill have him put it on a memory stick and then ill send it to who ever wants it.
Old 3-15-09, 12:48   #15 (permalink)
  Total: 205 Power: 5
i'm curious what times did the G35 get. did u beat him?
99 Audi A4 2.8 Quattro Stock
94 MX-6 LS Mods: KLZE, I/H/E, Hi-Flow Cat, Steel clutch line, RR poly inserts, Short throw shifter, ACT HDSS clutch, MX-3 flywheel, Chipped ECU, J-Specs w/HID, K-Sport coilovers, RSTB, FSTB, 22mm Rear Stabilizer, Clear side markers RIP - Dropped valve since March 2011
