hey there is a kid in hilsdale nh selling his ze that he was swapping into a protege he also has a lot of other stuff as well. found it on craiglist
Mazda Parts
KLZE Swap for a Protege, MX6, Probe GT, MX3:
1. 94 Mazda KLZE Straight Neck Manifold 2.5l v6 200hp - 63k miles. New Gaskets, everything cleaned up, manifold has been repainted, block, and heads are painted, Includes all new vacuum plumbing. - $1800
2. 1996 Mazda MX6 LS v6 5speed Tranny w/ intermediate Shaft and Working Starter. Freshly Painted and Cleaned - $450
3. DXD Racing Southbend Rally Series Stage 1 Clutch capable of holding 260ft/lbs. Good for any KL Series Motor - $150
4. KL Alternator working condition - $65
5. Mazda JE50 VAF for use with a JSpec KL31 or KL36 ECU and the KLZE motor. - $65
6. Mazda KL02 VAF for use with a Chipped Aspec ECU or replacement for a US Spec MX6/Probe GT - $45
7. Dakota Digital Universal Tachometer Interface. This is used to translate the v6 Tach signal into one a 4cyl stock gauge cluster can read. - $65
8. Slave Cylinder for any KL Series Motor. Brand New in box - $40
9. KF34 Distributor for any US Spec KL series Motor. 93-94 OBDI, working condition, comes with new seal and cap and rotor - $55
For a Protege you will need a 93-94 Wiring harness from a US Spec MX6 v6, Headers from PaceSetter, JSPec or Chipped ASpec ECU, timing belt kit, flywheel, and bolts to hold the transmission to the motor.
For pics about the swap:
Slotege KLZE Swap Thread - Mazda Forums
Miscellaneous Mazda Parts:
1. JSpec Distributor for a Mazda/Ford KL series motor, this came from my KLZE, cap and rotor included - $50 obo
2. Stock Mazda / Ford KLDE/KLZE Exhaust manifolds without Cats. No Cracks and all studs are in place. $60 obo for both
3. Headlights for a 1999-2000 Mazda Protege - $45 obo
4. Front Corner Lights for a 1999-2000 Mazda Protege - Amber - $30
5. Front Corner Lights for a 1999-2000 Mazda Protege - Clear - $25
6. Stock Shifter from a 3rd Gen Protege - 99-03 - Protege /Protege5 - $20
7. Injen Cold Air Intake w/ 2000 Toyota Celica MAF Sensor - 99-01 Protege DX, LX 1.6L only. - $100 without MAF, $150 with MAF
8. Gauge Cluster from a 2000 Mazda Protege LX 5 Speed w/ Keyless Entry 152,000 miles on odo - $35
9. Generic Brand Front Strut bar for any 3rd Gen Protege 99-03 Polished bar, black end plates - $20
10. Used Calipers from a 99-00 ES 1.8l, This is an upgrade from the 99-00 DX/LX. Just need Pads and rotors. - $50 obo
11. Front Fenders from a 99-00 Protege - Classic Red in color, no dents - $70 for both obo or $40 Each
12. Protege Trunk floor and carpet, minor stains on the carpet, no rips or tears. - $30 obo
13. Steering Wheel fro a 99-00 Protege w/ airbag, I Have two of these. Both are Gray in color. $125 Each
14. Center Console 99-00 Protege. Gray in color. Comes with the bracket for the shift boot, and armrest. Good Upgrade for a DX. $40 obo
15. Valve Cover Bronze in color w/ silver letters, Mazda 1.6l from a 99-001 Protege. $45 obo
16. Stock Rear Swaybar for a 99-00 Protege. Does not come with Endlinks or bushings. I have Two of these. $35 obo Each
17. Stock Front Motor Mount from a 2g MX-6 LS. No rips or tears in the rubber - $15 obo
18. Driver side power window and mirror controls. Gray in color - $10 obo
19. Radiator for a 99-00 Protege DX/LX 1.6L Good condition no cracks or leakes. - $30
20. A/C Condenser for a 99-00 Protege, no cracks or leaks - $40
21. Stock Tailights for a 3rd Gen 01-03 Protege. No Cracks, scratches, or scuffs. - $40
22. Stock Airbox for a 99-03 Protege ES 1.8/2.0 No cracks, includes MAF Seal. - $25
23. 99-00 Protege 5spd Tranny. 80k Miles, does not grind any gear, has been recently repainted, new speedo sensor. $300 obo
All payments will be cash in hand transactions. Plan to bring a vehicle to pick up the parts. I have many other miscellaneous parts for a 99-00 Protege. So contact me if you need a little piece here or there.
