Ok all you j-spec inlet manifold runners with a 94 > ECU take note..
I have a pair of MSD DIGITAL window switches, with the
VRIS connector plugs already on and ready to go, original box, and instructions.. You will no doubt know that with your 94 > wiring loom, you dont have the 2nd water temp sensor and dropping a j-spec ecu in to get the correct VRIS openign points and the best out of the manifold, is going to leave your fans constantly running.. well here is a solution.. I looking for £85 + p&p the pair, remember these are already wired into VRIS connections to save you the trouble. Pics below... i dont expect these to stay available very long, only available from the states.. so if your interested, be quick.
