Long time no whinge! But that's about to change.
Long story short, a new dizzy failed to resolve the issue. Several hours (and £400) later, the garage discovered the dizzy was incorrectly assembled. The eccentric was 180 degrees out!
So, they rebuilt that and fitted new fuel rails and off she went - Hurrah!
Drives well but is a bitch to start. Flooring the accelerator when turning her over stops the fuel injection and cures the starting issues. Diagnosis, leaky injectors - confirmed by the garage aftger putting a fuel pressure guage on the system. Not much we can do and there's a work-around so I'm going to live with that.... Or so I thought!
Coming home from London last night, she's flying
Cruising comfortably in 3 figures (once off the M25 car park that is) until, all of a sudden, serious loss of power. I found that lifting off completely resulted in enough power to limp home at 60 ish but as soon as I put any pressure on the accelerator she bogged down.
Same through town (I'm glad I'm only 1/2 a mile from the end of the motorway!) all I could use was the first 1/4" of accelerator travel.
This morning, she won't start at all so I'm stuck. I've got rid of the spares MX6 and just had the Tipo towed for scrap so I'm down to one (non-running) car.
This is where I call on the good nature of you lot! I need everyday transport for the 40 mile (each way) commute to work so if anyone has a car I can borrow or buy very cheap (over £1500 spent on the 6 so far this year so I'm totally skint!) I'd be eternally grateful.
And..... More importantly, can anyone help with the problems with the 6? Ideas as to what the problem could be would be a start. I'm still thinking fuel rails, but haven't been able to check that. The behaviour suggests to me that she was flooding as soon as you open the throttle.
All that's left to say is...... Help!!
Thanks guys
K.
