Hi Tallboy, welcome to the club.
From your post i'm assuming you have already purchased the aerial.
To remove the original mazda one, it is held in place by a single nut and bolt (attached to the aerial) located inside the boot,and The rubber mount top on the outside of the wing which is held in place by the silver ring screwing onto the top of the aerial. You need to remove both the nut and the rubber mount. If the new aerial you have bought does not have the bolt to mount in the boot then you only have the rubber mount left, and in my opinion is NOT a replacement. You can try it with just the rubber mount, but i think the torque of the motor kicking in will make the whole thing move around and put quite a bit of load on the mount. or you could tie-wrap it in the boot to stop it moving.
Oddy.
