Hi Ian,
I have a second set ready to do the other side but not being as young or as fit as I was, lying under a car with a junior hacksaw removing the old ones is not as easy as it used to be
. It may get done over the weekend or next weekend.
There could be a problem torquing the bolts as there is no obvious way of stopping the bolts turning unless they hold once nipped up, there is no 5mm Allen key hole in them. That was one reason I wondered if the nuts already on them should be left on and another nut put on to effect the fixing.
I guess these are generic parts as the studs are much longer than the orginals so I could put two nuts on them to act as locking nuts while tightening the fixing nuts but then I couldn't get a socket on and use a torque wrench.
Unless anyone comes up with a bright idea I guess it will be a case of using two lock nuts and heaving on a ring spanner until it feels like 27ft/lbs!
I guess I could cut down the studs on the other link before fitting and thus allow me to get a standard socket on and torque them up.
