Old 4-8-08, 15:22   #31 (permalink)
  Total: 60 Power: 5
thanks for clarifying that... wouldnt want my engine to die or something nasty just because i put the wrong oil in!
Old 5-8-08, 4:10   #32 (permalink)
  Total: 10 Power: 2
I just had the oil changed in My 94 V6 2.5 The masking tape in the engine bay said the last oil change was within 5000km of where I am now. I have 332,000+ on the odo. I had My local "Mr.Lube" put Full synthetic Mobil 1 in. Am I doing the right thing by using Fully synthetic on a high milage engine? Has anyone else here had an engine last this long? She's still smooth,quiet (when I keep my foot out of it, ha ha.) and strong.
Stratoviper is offline   Reply With Quote
Old 5-8-08, 6:47   #33 (permalink)
  Total: 23 Power: 5
If the engine is in good shape there is no issue using a synthetic on a high mileage engine.
Cheers
Guy.
oilmans website : www.opieoils.co.uk/
e-mail : oilman@opieoils.co.uk
tel : 01209 215164
MX6 club members get 10% Discount at Opieoils.co.uk
oilman is offline   Reply With Quote
Old 5-13-08, 10:16   #34 (permalink)
  Total: 1292 Power: 5
fredio54's Avatar
The man speaks the truth with regards additives. You should NEVER use them. Period. All oils are packaged with plenty of additives in them already.
With regards HLA ticking, using a light oil will (of course) make it noisier (hot number is key, not cold). There is no magic oil grade for making this go away, it is a prior maintenance issue that needs to be remedied by replacement or (much cheaper) cleaning as shown here :
http://www.mx6.com/forums/fe-dohc/10...ift-power.html (FE3 HLA cleaning procedure for more lift and power :-))
http://www.mx6.com/forums/2g-mx6-oth...less-tick.html (K series/FE3 HLA cleaning.(for more lift/power, and less tick))
Once clean, use ONLY full synthetic because the oil in the lifter is STAGNANT and does NOT circulate significantly during normal regular use. The HLA sits on the end of the valves getting nice and toasty and the oil (if mineral) eventually turns to coke (carbon). It is a physical defect. No oil (not even my favourite one (amsoil)) can fix that :-)
Agreed, but if it is dirty, the dirt is the seal, and it will get washed away! (speaks from personal oil stained driveway on low mileage jap engine that was typically jap dirty)
Just thought I'd share my knowledge on that with you lot :-)
Fred.
Old 6-15-08, 16:55   #35 (permalink)
  Total: 23 Power: 5
Hi guys
Anyone need a recommendation?
tel : 01209 215164
Old 6-15-08, 18:27   #36 (permalink)
  Total: 13 Power: 2
Originally Posted by oilman View Post
Hi guys
Yea I got one.
92 manual box, getting hard to change gear at top RPM, what oil will help make this better? Tried to speak to you at the JapFest, but you were swamped.
nasher is offline   Reply With Quote
Old 6-16-08, 8:11   #37 (permalink)
  Total: 23 Power: 5
Is it just getting baulky/stiff or does it grind into gear at high revs?
Cheers
Guy.
tel : 01209 215164
Old 6-16-08, 13:52   #38 (permalink)
  Total: 13 Power: 2
Cheers
Guy.
Hey Guy
Its great at all changes at any revs up to 6000, then you have to give it a good shove to get it in. Also noticable on the change down at high revs.
Mike
Old 6-16-08, 15:04   #39 (permalink)
  Total: 23 Power: 5
It does sound more mechanical than oily
Cheers
tel : 01209 215164
Old 6-19-08, 5:02   #40 (permalink)
  Total: 37 Power: 3
im gonna join in on the gearbox thing, i have a g-series 5 speed manual and it crunches chen cold and sounds alot more mechanical than oily. im using the oil mazda reccomend i cant remember exactly but it was something like ?w-90
btw this box has only done about 70xxx kms but i drove it without a clutch for about 10km... oil has been changed since then. i change the oil in the box every seccond engine oil change so i do it about every 10xxx kms
She got torque? Yer she pulls like a 15 year old.
Originally Posted by compnut21 View Post
or you could have done what i did and left a screwdriver under the valve cover
tx5_brent is offline   Reply With Quote
Old 6-19-08, 8:51   #41 (permalink)
  Total: 23 Power: 5
Might be worth you getting your syn chros looked at, I remember when my old vw clutch went and drove it home 10 miles. Syncros had had it after that.
But I had a spare gearbox anyways so wasnt too worried.
Cheers
Guy.
tel : 01209 215164
Old 9-11-08, 8:22   #42 (permalink)
  Total: 37 Power: 3
probably should have done that. That gear box is now gead, 1st gear makes horrable noises when at WOT, but, I have a new gearbox ready to go in and a new motor. The new motor and box will be reciving some of Australia's finest oils. 10w-40 for the motor, fully synthetic. Not sure on all of the specs, but, im getting it off jessiotrot so he knows what he is doing.
Old 10-13-08, 16:34   #43 (permalink)
  Total: 10 Power: 3
Hi,
I use some Castrol GTX A3/B3 oil and change it every 5000km (3000Miles) with the oil filter.
What about the Metal 5 additive (Metal5) ?
Tommy O'Shea : Do guns make you nervous?
Paul Kersey: Guns have their uses. Idiots with guns make me nervous.
le_cornouiller is offline   Reply With Quote
Old 1-5-09, 7:58   #44 (permalink)
  Total: 23 Power: 5
Any advice on oil required, please feel free to ask as I can help you
You will also find some useful info on my website here
Car Oil & Filter service packs
All the best for 2009
Cheers
Guy
tel : 01209 215164
Old 1-21-09, 0:30   #45 (permalink)
  Total: 20 Power: 5
ElmerFud's Avatar
Hi Guy
Like the new website.
Does your UFI oil filter ref 23.265.00, as recommended by your site, have the much vaunted 'non return valve'?
Mark
TWR full body kit, mesh grill, Custom paint: Bluish black, ice violet flake, CAI, Denso irridiums, Magnecors 9mm, SS headers Scorpion Exhaust, KYB shocks, Spax springs - lowered 35mm, HIDs, Reverse glow dials & chrome rings, Momo gear knob, RR Racing short shifter, 18" Team Dynamics RVRII alloys, Toyo T1R's, EBC Green stuff, Red calipers with Mazda decals, High performance engine mounts, Chrome boot struts, Genuine Isotta Vallelunga.
ElmerFud is offline   Reply With Quote
