Old 7-28-05, 11:01   #1 (permalink)
  Total: 41 Power: 5
Willr's Avatar
MX6 Jargon Explained
2WS: 2 Wheel Steering
4WS: 4 Wheel Steering
A/C: Air Conditioner
ABDC: After Bottom Dead Centre
ABS: Antilock Braking System
AC - Air con
ACC: Accessories
ATDC: After Top Dead Centre
ATF: Automatic Transmission Fluid
ATX - automatic transmission
AWD - All Wheel Drive
BAC: Bypass Air Control
BBDC: Before Bottom Dead Centre
BTDC: Before Top Dead Centre
CAI- cold air intake
CEL - a check engine light
CLT - Coolant Temp Sensor
CPU: Central Processing Unit (not the ECU)
CSI: Cold Start Injector
CTQ - Crank Torque
CU: Control Unit
EC-AT: Electronically Controlled Automatic Transmission
ECU- Engine Control Unit
EGI: Electronic Gasoline Injection
EGR: Exhaust Gas Recirculation
ESA: Electronic Spark Advance
ESPS: Engine Speed sensing Power Steering
EW - electric windows
EX: Exhaust
FWD - Front Wheel Drive
HLA - Hydraulic Lash Adjusters (similar to tappets)
HU: Hydraulic Unit
I/H/E- intake/headers/exhaust
IAC - Intake Air Control Valve
IAS - Idle Air Screw
IAT - Intake Air Temp Sensor
IC: Integrated Circuit
ICE- In Car Entertainment
IG: Ignition
IN: Intake
ISC: Idle Speed Control
JDM/USDM- Japanese Domestic Market / United States Domestic Market
JSPEC/ASPEC/ESPEC- Japanese/America/Euro
LH: Left Hand
MAF - Mass air flow
MTX - Manual Transmition
O/D: Overdrive
P/S: Power Steering
PAS - Power assisted steering
PCV: Positive Crankcase Ventilation
PRC: Pressure Regulator Control
RWD - Rear Wheel Drive
SC - Supercharger
SST: Special Service Tool
TB – Throttle Body
TDC: Top Dead Centre
TNS: Tail, Number, Side (lights)
TPS- Throttle Position Sensor
VAF - Volume Air Flow
VAPS - Variable Adjust Power Steering
VC - Valve Cover
VCG - Valve Cover Gasket
VRIS - Variable Resonance Induction System
"Duct tape is like The Force - It has a light side, a dark side, and it hold the universe together"
Willr is offline   Reply With Quote
