with regards to bubbles in the sight glass..
run the A/C for a few minutes.
1. bubbles seen: not enough gas.
2. no bubbles: too much, or correct amount.
have someone turn off A/C while looking at sight glass.
1. stays clear: too much.
2. foams, then clears: correct amount.
If all is fine, you will need to get the pressure tested, both high and low side..
normally this is:
Low: 21-43psi
High: 185-213psi
if it's outside the spec, let me know what the readings are, and I can tell you what is wrong..
1. too much
2. too little
3. air in system
4. moisture in system
5. no circulation
6. expansion valve stuck
7. faulty compressor
John
