Old 12-20-06, 16:50   #1 (permalink)
  Total: 11 Power: 5
coolant hoses
I am right in thinking that the coolant hoses on the 6 are exactly same as those on the probe yeah??
Thought id check before going n spending money to find out ive gone wrong.
thanks guys
essxmx6 is offline   Reply With Quote
Old 12-20-06, 17:25   #2 (permalink)
  Total: 537 Power: 5
If i remember correctly, someone has mentioned in the past the top radiator hose is either longer or shorter.. but right at this min i cannot remember which
Paul.
Gone...
Old 12-20-06, 17:51   #3 (permalink)
  Total: 67 Power: 0
There are a few differences - enough to make spending the money pointless.
I know these guys can sort it for you by making some to your spec -
www.dmemotorsport.co.uk
Ben
Old 12-22-06, 9:38   #4 (permalink)
  Total: 86 Power: 5
The Probe top hose is about 2" longer than the 6 hose, although it can be cut to fit.
I strongly suspect the bottom hose is also different.
ifc
Forgiven - maybe
Forgotten - not likely
Old 12-22-06, 9:51   #5 (permalink)
  Total: 537 Power: 5
ifc
Thanks Ian .. i still had'nt remembered or managed to clear it up ..
Paul.
Gone...
Old 12-22-06, 9:57   #6 (permalink)
  Total: 11 Power: 5
ok thanks ill have a look at the link
saved some money there then
Old 12-24-06, 6:50   #7 (permalink)
  Total: 86 Power: 5
Dme
Had a brief look at their homepage - is that an MX-6 in the Santa Pod picture?
ifc
Forgiven - maybe
Old 12-26-06, 5:55   #8 (permalink)
  Total: 67 Power: 0
Nope - thats a Nissan 200sx S15. Bit of a beast as well that car - I've had a good look round it.
Ben.
Old 12-26-06, 7:17   #9 (permalink)
  Total: 1714 Power: 5
Fastest95PGT's Avatar
If anyone has ever looked in both a Probe *and* MX-6 engine bay.. you'll notice the motor is a good 2" closer to the radiator on the MX-6 than it is in a Probe.
The lower hose *might* stretch to fit. The upper one is definitely off as described though.
PARTING A LOT OF 2g STUFF
