Old 12-18-07, 12:46   #1 (permalink)
  Total: 18 Power: 5
fuel question please help me sort this out
im getting fed up with trying to sort this problem out.
i think my starting trouble might be fuel pump, cars going great but does not start when u let it cool down after a run, fine when hot and cold.
can u hear the fuel pump when u turn ignition on? and could fuel filter make this problem, and would i have to put in a propper mx6 fuel filter or would a plastic in line one b ok
mazdamatt is offline   Reply With Quote
Old 12-18-07, 13:04   #2 (permalink)
  Total: 42 Power: 5
Storm's Avatar
as far as the fuel filter goes - have you seen the size of the fuel filter on a 6? Definetly original is best - and not too expensive.
Poor starting after cooldown? When was it last serviced? Could it be a plugs/leads problem? When you say "it does not start - does it turn over and fail to catch or what? More info will helpus solve the problem.
G
The Hairy Haggis
"A Scottish Moderator, Well I never............. "
Storm is offline   Reply With Quote
Old 12-18-07, 13:08   #3 (permalink)
  Total: 18 Power: 5
its not like flat battery.
it has new plugs leads dizzy, o2's air flow meter, u name it its done. it just turns over for a very long time, does attempt to start but wont till 2nd or 3rd time.
Old 12-18-07, 13:08   #4 (permalink)
  Total: 67 Power: 0
Grahame, I think Matt has been on the merry go round on this one in terms of describing the problem and not getting anywhere. Matt, have you asked a decent mechanic to have a look at it?
Ben.
Old 12-18-07, 13:11   #5 (permalink)
  Total: 18 Power: 5
ive been given stupid answers, my mates a mechanic he said by a new dizzy, did that but still the same, cars running sweet as a nut is like if i go out shopping come back wont go, always starts but struggles. the car has a new j spec engine i have fitted
just put on a universal fuel filter but not happy it fits very well, seems very sluggish starting all the time with this one.
i thought maybee fuel pumps getting tired
Old 12-18-07, 13:12   #6 (permalink)
  Total: 18 Power: 5
could it be crank sensor dirty? im only thinking fuel coz ive done everything else
Old 12-18-07, 13:50   #7 (permalink)
  Total: 20 Power: 0
dude this sounds like your head gasket or cracked block, theres coolant in your cylinder and when your motor is warm not enought air/fuel is going in.i had the same problem on quad4 motor
DimaK is offline   Reply With Quote
Old 12-18-07, 13:55   #8 (permalink)
  Total: 18 Power: 5
no way ive just driven on a 4 hour journey with it, its not that serious, if u acelerate a bit it starts right up, not that, the cars always had this problem even before i put this engine in. its runnig great, its as if the fuel pressure drops, its alright if u let it cool down, and its alright when its hot, oils very clean waters perfect.
Old 12-18-07, 15:07   #9 (permalink)
  Total: 1000 Power: 5
Einstein's Avatar
I doubt this is electrical, or down to the fuel supply..
This sounds more like an air leak, or a problem with the BAC valve... possibly the coolant hoses to the valve body...
You say it will start if you open the throttle a bit.. and that is the clue I think...
John
"Lexarse" GS 300
Still got zoom zoom zoom!
Old 12-18-07, 15:10   #10 (permalink)
  Total: 18 Power: 5
is that under the throttle body, is there a chance the water pipes might be the wrong way round, i take it its the ones that go to the heater, or a new throttle housing
yep starts loads better if u push throttle down
Old 12-18-07, 15:34   #11 (permalink)
  Total: 18 Power: 5
ive been over and over the vacum pipes and everything cant find anair leak,
Old 12-18-07, 17:34   #12 (permalink)
Einstein's Avatar
Yes, under the TB... are the pipes partially blocked by any chance?
The water heats the valve, and controls the cold start device.. (like a choke)
It may not be a pipe, although it usually is.. cracked, split etc..
could also be where the pipes connect.. and also check the rubber elbow between the TB and VAF very carefully... another common problem for cracking.
John
"Lexarse" GS 300
Old 12-18-07, 18:33   #13 (permalink)
  Total: 18 Power: 5
the rubber pipe to vaf is perfect, i think the bottom water pipes are good as they run in to the heater, is it worth getting a throttle housing
Old 12-18-07, 18:35   #14 (permalink)
  Total: 18 Power: 5
actually the cold start pipes they arent the vacum ones coz they are fine, are the pipes air or water?
Old 12-18-07, 18:36   #15 (permalink)
Einstein's Avatar
I would be tempted to "borrow" one.. sure someone could help..
If it cures the problem, then you know what to do.. offer to buy it, or find another..
John
"Lexarse" GS 300
