Hi all new to board and looking for some info......
i have a 1996 v6 auto. replaced head gaskit and water pump,,, now shel turn over no prob,new battery good spark to all new plugs cap and rotor arm,,got fuel to the rail via new fillter, pump working fine,, crank sensor replaced,, but still will not fire up....
am getting short of ideas now, am going to borrow a mates dizzy soon incase cam sensor dodgy, but wondered if anyone has ideas for me to try .
The problem you are experiencing may have several solutions - first question for you is: you seem to have done a bit of work already - head gasket, water pump, battery, plugs and dizzy cap - is there a particular reason for this?
How long have you had the car and why have you replaced parts in the order you have done?
The dizzy is certainly a known problem on early cars but not usually on a '96. On earlier cars, the ignitor module can go - may be worth checking, but if you give us a bit more info, maybe we can come up with alternatives for you.
Graeme
The Hairy Haggis
"A Scottish Moderator, Well I never............. "
hi
bought car from brother it had a blown head gasket so the rac told him, so replaced the gaskets ,and valve seals aswell, the water pump was leaking so replaced it, then did full service all filters,plugs,belts,oils, shel turn over lovly but will not fire, ive placed paper under the injectors and wound her over but no fuel came out allthough fuel rail full, changed crank sensor as now this will stop injectors from pulsing, am at a loss at mo
are you sure the timing belt went on correctly after the head was removed/replaced?
edit..
are you saying you have removed the rails from the intake, connected them up and cranked her over and no fuel flowed..but you have fuel pressure ?
first of all pull the error codes to check input sensors..
if that comes up empty take one plug of an injector rail...make sure you have a 12v+ on the wire on the end of the connector and that you get a pulse of a ground on the other 3 when cranking..(best with analog volt meter cos its kind-a fast)
if you dont get +12 v when keys are in the on position you have probably lifted a fuse..
if you dont get the pulse of -12v then either the ecu is stuffed or the input that tells it to fire is shot..
If you aren't living on the edge...Your taking up to much space..
Double check the valve timing for a start.. (no pun intended )
Forget the dizzy and electrics, as you say you have a spark..
Injectors are fired from the ECU, and it also controls the pump...
With any engine, fuel + compression + spark all at the right time should make it fire..
My guess is valve timing maybe out.. try a compression check... see if the plugs are wet with fuel..
John
Thanks all for help so far.
yes i did lift fuel rails and placed paper under them,nowt came out,
have tryed coeds but nothing shows up on dash atall,
when you say check valve timing do you mean removing the rockers and check the markings again on the inside of cams,, or the marks via timing belt ,,sorry i bit thick sometimes,,
if the ecu buggerd how will i now ,and can i replace it with a second hand one from nother car,,,,also input that tells injectors to fire crank+cam sensors i think are there anyothers
will be able to work on car moro so will check and double check again..
I've been wrong before... but you are saying you are not getting fuel out of the injectors...you have fuel pressure
surly its a problem with the injector "firing".. even if the valve timing or anything was out it would still fire/flow fuel out of the injectors...?
hi all
just spent 2 hours in the freezing cold and wet checking everything over again to no avail,,,,
have tested dizzy its ok giving out signal,,
crank sesnor ok,,,
nothing showing up on dash from code reader,,,
not getting any resistance readings from the injector harness for any injector,,
im at a loss now does this mean that my pcm is shot ?
can i test it in anyway,,,,
will a second hand one just plug straight in and would a 93 one be ok for my 96 ????????????
We all presume you are in the UK... if so, you won't have a CEL (Check Engine Light) as UK cars never had one..
You short TEN & GND and use a 12V LED or regular LED with 10K resistor inline, inserted int B+ and FEN... turn on the ignition, and count the flashes..
Also.. check or replace the MAIN Relay.. (looking from side of car, middle relay of 3 on far right hand side, nearest windscreen)
Don't think it's your ECU as you are getting a spark.. although you may want to check all the electrical connections just to be sure..
John
yep im in uk,, Have tryed the relay [ middle yellow for me} and replaced it so have 2 now to use,,,
will try the codes again moro with 12v led i have a few in the shed,,
yes def,got a good spark on all plugs;will checf every wire moro as well
if you have no fuel flow.. than that IS you problem not the spark.. you have a ge2 yea.... i say your crank position sensor is gone.. PULL THEM CODES!!!!
