#16 (permalink) | |
Check the voltage at the dizzy connector...
rear most pin of 3 pin connector from memory.. should be 12V from ignition switch.. Check MAIN and IG KEY fuses under the bonnet.. John |
#19 (permalink) | |
Yes Matt, they feed power to the dizzy..
If you test for power at the dizzy, and you get 12V on the 3rd pin (possibly black with white stripe) then don't bother checking the fuse, as all is well.. Any other fault would be a wiring problem, the dizzy or ECU.. the latter two being unlikely.. John |
#22 (permalink) | |
Did you check for power going to the dizzy?
and I presume you are still checking for a spark... John |
#24 (permalink) | |
Basically, the CPS in the dizzy sends a signal to the ECU, this in turn sends a signal back to the Ignitor module, and then to the coil and plugs.
If there is no spark, the only things it could be are the Wiring, Dizzy, or ECU It is unlikely all 6 leads, and plugs are shot.. John |
#27 (permalink) |
Matt,
Can you do me a favour and connect the lead to the power steering pump please and try her. Its actually being listed as one of the electronic advance control system sensors .. to the best of my knowledge, this lead is what tells your steering to stiffen up at speed, but hey .. lets give it a go as you mention its not connected..Paul. |
Current Ride and new project- 93 Cavalier Turbo, running approx 260 at 12psi on phase one chips.
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ R.I.P 92 2nd gen HYBRID - ZE cams, ZE inlet manifold, Mag leads, 65mm TB, CAI, Tokico shocks springs, SS headers, SS DE-cat, SS Scorpion cat back, 17in Wolfrace Osaka alloys - pics ==>My Album |
#28 (permalink) |
Forget the PS wire, i have just found another section stating the engine will fire without out.
Also, and sorry to be thorough... VAF on the right way around ? and if an auto, is everything connected on the box. Are we checking for spark on different parts of the body to ensure earths are good ? Also check for codes ... Paul. |
#30 (permalink) |
evrythings connected fine, tried 3 dizzys that work on my other mx6, tried loads of ecu's, wiring looks fine, im really stuck, got a garage looking at it tomorrow, they are bringing some sort of laptop to plug in to it, its only showing fault code for fuel pressure regulator but thats nothing,
gonna try the earths again later |
