Old 5-12-08, 12:07   #31 (permalink)
  Total: 18 Power: 3
yep earthing the plug properly to test, thats fine, had the help of texmex all afternoon yesterday
mazdamatt is offline   Reply With Quote
Old 5-13-08, 10:11   #32 (permalink)
  Total: 29 Power: 4
You haven't said but it is turning over on the key isn't it?
Gerry
www.rcmf.co.uk
www.namfc.co.uk
Old 5-13-08, 11:23   #33 (permalink)
  Total: 18 Power: 3
oh yea turning over fine, everythings fine just no spark
Old 5-13-08, 14:43   #34 (permalink)
  Total: 29 Power: 4
I would now test to see if the ignitor is working. I don't have a wiring diagram to hand but you need to unplug the dizzy, give it some power through the necessary connections then trigger it by taking the lead that would have been connected to the ecu positive. I would use a 1.5v pencell with the negative connected to earth and touch the positive connection on the dizzy trigger. 1.5v should be enough to trigger it but if you get no spark try a PP3 9v.
Gerry
www.rcmf.co.uk
www.namfc.co.uk
Old 5-13-08, 16:20   #35 (permalink)
  Total: 18 Power: 3
got it going very bad connections
Old 5-13-08, 16:34   #36 (permalink)
  Total: 444 Power: 5
Einstein's Avatar
Result !!!!
at last
"Lexarse" GS 300
Still got zoom zoom zoom!
Old 5-13-08, 16:42   #37 (permalink)
  Total: 428 Power: 5
Oddball's Avatar
Just for future ref... the bad connections were ???
Paul.
92 2nd gen HYBRID - ZE cams, ZE inlet manifold, ZE ECU, JE50 VAF, port matched outlaw inlet spacers Mag 8.5 leads, 65mm TB, CAI
Tokico shocks springs, SS Auto headers, SS DE-cat, SS Scorpion cat back, 17in Wolfrace Osaka alloys
Old 5-13-08, 17:17   #38 (permalink)
  Total: 18 Power: 3
almost every earth to the gear box, the big one on the gear box mount was all green inside, we cleaned it up and then the fuel pump would not work, so gonna run the earths straight to the battery, so my next day off ill have it sorted, ran sweet did not see any smoke
Old 5-14-08, 2:00   #39 (permalink)
  Total: 11 Power: 1
fandabbydossy,,glad you got it running :jum p:
Lee,,,,
mazda1109 is offline   Reply With Quote
Old 5-14-08, 11:29   #40 (permalink)
  Total: 18 Power: 3
oh yes thank god, needs a bit of playing around with as the choke did not seem to work, im thinking it needed to warm up for the thermostat to open and then the water will circulate to work the choke next time, if not its only throttle body any way got hundreds of them
Old 5-15-08, 11:24   #41 (permalink)
  Total: 18 Power: 3
just drove it back from my workshop, seems sweet, very quiet the mx3 flywheel really makes the speed pick up
Old 5-15-08, 11:25   #42 (permalink)
  Total: 46 Power: 4
You cannot know how jealous I am.
Ben.
Ladies and Gents - SOON TO ARRIVE -
The Fastest 6 in the midlands...
Full KLZE rebuild, the proverbial works!
Its all in progress - updates soon...
Old 5-15-08, 11:54   #43 (permalink)
  Total: 18 Power: 3
im sure ull get it sorted soon, always teathing problems
