#17 (permalink) |
thank you so much
just looked unfortunately breathers are the right way round but on that system it is missing the rubber elbow, to connect to the rear rocker so back to scratch it looks like im really hoing its lambas i really am can i use universal ones or do they have to be specific?? cheers chris |
#19 (permalink) |
mmm .. not good eh ..
So the metal pipe just ends at the back of the rocker cover under the inlet manifold ? if so this is causing a big vac leak, you need to either connect it up or block off each port to stop the leak... at the moment you are probably finding it idles bad with these open.. I would also check the drivebelt timing if possible to ensure its not the valve timing out and causing excessive blow by. Go over each of the diagrams provided, ensure you have the pipes as they should be, and solenoids / sensors connected. You will be amazed how many people miss some, even after going over them a number of times.. Paul. |
92 2nd gen HYBRID - ZE cams, ZE inlet manifold, ZE ECU, JE50 VAF, port matched outlaw inlet spacers Mag 8.5 leads, 65mm TB, CAI Tokico shocks springs, SS Auto headers, SS DE-cat, SS Scorpion cat back, 17in Wolfrace Osaka alloys
