Rear Drop link Rubber Bush - Mazda MX6 Forums: MX6 Forum
Old 5-13-09, 11:32   #1 (permalink)
  Total: 17 Power: 5
I have the got the classic tap tap tap from the boot area. I had a look under and one of the drop link rubber bushes is worn. I'm sure i remember seeing in past posts that Nissan Micra bushes are the same, but cost a whole lot less? Has anyone done this job and am i correct about the Micra fitting? Any answers gratefully accepted .......Adrian
pro-kart is offline   Reply With Quote
Old 5-13-09, 12:46   #2 (permalink)
  Total: 45 Power: 5
MX6 addict's Avatar
They are only £8 each from the Porbestore
Ford Probe Store/Mazda Store - Ford Probe Spares - Mazda Parts - Specialists for Ford Probe, Mazda MX-3, MX-5, MX-6, Mazda 6, 626, Xedos & 323F, Spares & Modifications
Mark
Old 5-13-09, 12:58   #3 (permalink)
  Total: 0 Power: 0
Hi Guys,
When I go over certain bumps in the road but only very occasionally, I get a thump from the rear which sounds like something loose in the boot.
Is this the same problem as pro-karts?
Mark, have you a section detailing this problem and diagrams from the Workshop Manual?
Oh yes, is this an MOT failure?
Paula
Old 5-13-09, 13:02   #4 (permalink)
  Total: 45 Power: 5
MX6 addict's Avatar
Originally Posted by Paula View Post
Hi Guys,
Paula
Could be. If they are gone they usually are quite loose and its an easy check, just get underneath and give them a bit of a twizzle.
Mark
Old 5-13-09, 13:12   #6 (permalink)
  Total: 45 Power: 5
MX6 addict's Avatar
Yep
Mark
Old 5-13-09, 13:17   #7 (permalink)
  Total: 0 Power: 0
Grin
Hiya Mark,
Thanks for that.
I will get twizzling in the morning ....
Paula
Mark
Old 5-13-09, 13:18   #8 (permalink)
  Total: 0 Power: 0
Cheers Mark ....
How was Brands by the way?
Yep
Mark
Old 5-13-09, 13:33   #9 (permalink)
  Total: 0 Power: 0
Hi again Mark,
I have just been looking in my Haynes Repair Manual for the Mazda 626, MX6 and Ford Probe and is this the correct section titled 12 Stabilizer bar (rear) - removal and installation with illustrations 12.2 and 12.3?
Cheers
Paula
Old 5-13-09, 14:08   #10 (permalink)
  Total: 45 Power: 5
MX6 addict's Avatar
Hi Paula, if you look at page 10-3 the bottom picture arrows the stableizer link bar (item 2), that's the little bliter. It's about four inches long.
They are more difficult to remove that to fit.
As you can see it looks a bit like a dogs bone, a bar with a top bit and a bottom bit. The top and bottom have a threaded bar coming out (you can just see it on the right hand side of the top bit). The threaded bar is mounted in rubber in the link, so because the link has been on the car for some time the nut will be well and trully on, when you try to undo the nut it will grip the thread and if the rubber its mounted in isnt already loose it will be.
They know this happens so the threaded bar has an allen key fitting in the end so as you undo the nut you can hold the threaded bit with the allen key.
Best advice I can give is to give the threaded bit a good clean with a wire brush and a good spray with WD40 or budge so the nut has a little friction as possible on the way off.
Putting the new one on is easy, just put it in place, put the nut on, put the allen key in and tighten the nut.
They sometimes come off OK, my neighbour got one off his Saab in ten mins!
Mark
Old 5-13-09, 14:27   #11 (permalink)
  Total: 17 Power: 5
Mark, many thanks for the info, looks like I'll replace both sides as they seem to be a very reasonable price.
Paula if you have light metallic tapping sound particularly when going slow over light bumps then its the same as me. I only just noticed it coming home tonight. I thought it was something loose in the boot, so drove with the rear seats folded down and soon realized it was coming from the rear axle area. Adrian
Old 5-13-09, 17:35   #12 (permalink)
  Total: 0 Power: 0
Grin
Hi Mark,
Many thanks for this information.
I'll pop underneath if it's dry in the morning and report back to you.
I assume that it is more an annoyance than anything else and the car will still pass an MOT?
Nitey nite
Paula
Mark
Old 5-13-09, 17:39   #13 (permalink)
  Total: 0 Power: 0
Grin
Hiya Adrian,
Yes my car is the same.
It only seems to happen at relatively low speed ( say between 30 and 50mph) and over light bumps.
Cheers hun.
Nite
Paula
PS. I have had the exhaust mountings all checked and nothing on the exhaust system is clouting the body or chassis underneath.
Old 5-14-09, 1:43   #14 (permalink)
  Total: 45 Power: 5
MX6 addict's Avatar
Hi Mark,
Nitey nite
Paula
If it's not functioning it usually is an advisory on an MOT. If it's broke (in two pieces) it's a failure.
Mark
Old 5-14-09, 2:43   #15 (permalink)
  Total: 0 Power: 0
Grin
Thanks Mark.....
It's dry just now so when I have had my morning tea & toast, I'll crawl under BaBaKa and have a look.
Back later
Paula
Mark
