Old 9-9-09, 13:46   #1 (permalink)
  Total: 18 Power: 1
Boot lock barrel
Anyone have one? Mine failed before Trax and I need a replacement.
Cheers
Rob
MazdaRob is offline   Reply With Quote
Old 9-9-09, 15:07   #2 (permalink)
  Total: 45 Power: 5
Cheers
Rob
I can probably sort you out with a full set of locks Rob.
Mark
Old 9-9-09, 18:00   #3 (permalink)
  Total: 18 Power: 1
Mark
How much mate?
Rob
Old 9-10-09, 2:08   #4 (permalink)
  Total: 45 Power: 5
Let me see what I've got. I must have one full set of locks, probably two.
Mark
Old 9-10-09, 2:50   #5 (permalink)
  Total: 45 Power: 5
Rob, before you go about swapping all the locks have a go at giving it a clean, it's only levers that pop together.
This is the manual page about the lock barrel
Mark
Old 9-12-09, 7:59   #6 (permalink)
  Total: 18 Power: 1
Mark
Just had a quick look now. Appears to be a rusty part at the bottom with a spring located above it. This part doesn't misses the rod that operates the lock by a distance when the button is pushed in. I assume it's supposed to. I'm going to take it out later and see if I can clean it up.
Rob
Old 9-16-09, 6:03   #7 (permalink)
  Total: 45 Power: 5
Hi rob, I don't know if you got my text or not but I have dug out the boot lock.
The lock seem's to be in OK condition but the key dosent go all the way in. You might be able to replace it with your key barrel, other than that the lock works fine (no rust), you might even be able to replace the bit on your's that has rusted.
If you want a look at it give me a call.
Mark
Old 9-16-09, 20:11   #8 (permalink)
  Total: 18 Power: 1
Mark
My phone's been on the blink Mark, but I did eventually manage to pick your text up, though a couple of days too late.
I'd like to have a look at the lock. I don't use a key in the boot lock as it's central locked, so the key isn't an essential. If the CL goes though, it'll need to work.
I'll give you a call before the weekend, I'm off to Wales on Saturday afternoon so if you're free Saturday morning, that'd be good
Rob
