Ahhh I see what you've done now.
Unfortunately this is a mistake that a lot of people make. The brake lines on the MX-6 are crossovers - if you bleed from the master, it only gets half the system. There's usually a lot of air trapped in the other section. So well done, you've figured it out and got it sorted.
The brake light comes on because it also acts as a warning light for low braking fluid. The sensor is in the reservoir, and all you have to do is simply fill it up as much as is sensibly possible. That stops it. You've gotten rid of a lot of air by the sounds of it, so the system is now holding more fluid.
Ben.
