#61 (permalink) | |
1996 Manual 2.5GT
#62 (permalink) |
Actually, that statement is not entirely true
, it needs to be removed or edited.. You would most probably LOOSE power through certain areas of the rev range using a ZE ecu on a std uk motor, and i very much doubt you would gain any anywhere through the rev range. You need to understand that the vris system is not some sort of power bolt on... it simply opens butterflies within the inlet manifold to make the tract longer and shorter, and harmonises the inlet to the engines rpm's. The opening points are determined to give the best overall performance from the design of the inlet manifold, changing these points (i.e. bolting in a ze ecu) will have a detrimental affect to how effective the inlet manifold works and would probably produce flatspots and surges through the rev range as the harmonics and rpms meet and pass. The ZE inlet design is very different to the std UK one, and so are the vris opening points. So, a ZE ecu attached to a DE engine running a DE inlet is no good.. bolt a ze inlet onto the de engine, and the ze ecu is good. These should always be considered a set ... ze ecu, je50 vaf, ze inlet. None of these components will work/gain power alone. Paul. |
92 2nd gen HYBRID - ZE cams, ZE inlet manifold, ZE ECU, JE50 VAF, port matched outlaw inlet spacers Mag 8.5 leads, 65mm TB, CAI Tokico shocks springs, SS Auto headers, SS DE-cat, SS Scorpion cat back, 17in Wolfrace Osaka alloys
#63 (permalink) | |
#64 (permalink) | ||
Ken
#65 (permalink) | |
Ken
