Be Quick - Mazda MX6 Forums: MX6 Forum
Old 9-16-03, 6:58   #1 (permalink)
  Total: 17 Power: 5
Be Quick
http://www.fpoc.co.uk/forums/viewtopic.php?t=585
Magnecores for £40
uk-mx6 is offline   Reply With Quote
Old 9-16-03, 7:01   #2 (permalink)
  Total: 26 Power: 5
cruisemad's Avatar
Hmmm daves still floating round the forum then...
MEMBER OF THE YEAR 2005
AKA CLUTCHMEISTER
Old 9-16-03, 7:14   #3 (permalink)
  Total: 15 Power: 5
UK-MX6? thought Dave was MX6-uk - maybe it's the ghost of Dave
Rio Red 16v probe
green induction kit, powerflow exhaust and front pipe, lower suspension, 24v wheels
Andy W is offline   Reply With Quote
Old 9-16-03, 7:41   #4 (permalink)
  Total: 26 Power: 5
cruisemad's Avatar
Had this discussion the other day.
Dave at home is MX6-UK
Dave at work is UK-MX6
Kyle
AKA CLUTCHMEISTER
Old 9-16-03, 8:11   #5 (permalink)
  Total: 27 Power: 5
Maputosimon's Avatar
I'm on the case! Wil they fit my car??
Maputosimon is offline   Reply With Quote
Old 9-16-03, 8:24   #6 (permalink)
  Total: 26 Power: 5
cruisemad's Avatar
You would need to check. I was going to fit them to mine but just realised im running the J-Spec ignition which is different. DOH!!!
AKA CLUTCHMEISTER
Old 9-16-03, 8:45   #7 (permalink)
  Total: 43 Power: 5
Its a good price - just check your distributor first, as explained in the ad ..
G
G-Force
Ex MX6 Owner ( 3 yrs )
Now: Supercharged CLK
Old 9-16-03, 9:18   #8 (permalink)
  Total: 27 Power: 5
I'm driving up to meet him now - the dizzy is different, but his last set of leads came off a car which had my lead order on the dizzy and they fitted fine - so we'll test it!
Old 9-16-03, 12:30   #9 (permalink)
  Total: 28 Power: 5
I emailed Magnecore a while ago and the red leads were not compatable with my car only the blue ones.
Mods So Far - Clear indicators, Momo Gear Knob, Reverse White Indeglo Dials, Front Strut Brace, Carbon Fibre/Chrome Pedals, EBC Turbo Groove Discs & Greenstuff Pads, 7mm Blue Magnecor ignition leads.19" team dynamic diablos alloys, pirelli p7000 tyres. Wizard of NOS kit.
Kimbelle is offline   Reply With Quote
Old 9-16-03, 13:31   #10 (permalink)
  Total: 27 Power: 5
You can give Phil De Witt @ Magnecore your exact lead lengths and he will make them to fit for around £135.
Well, I've got them on, and the car is a lot smoother!@-
These are the size which were not supposed to fit, but the only real difference is that the lead for cylinder 2 is shorter, so I've run it across the tops of the leads going into cylinders 4 and 6 to the dizzy.
Grendal's running a Probe with a MX-6 J-spec engine, Pipercross induction kit and full free-flowing decat system @ over 2.5 inches. He's also got an FSE.
Wasn't as fast as I thought it would be with the full exhaust system and FSE in addition to what I've got...maybe a: the exhaust diameter is TOO large and he's lost some necessary back-pressure, and b: the engine needs retuning after having had the FSE fitted. LOVELY CAR, THOUGH! Exhaust note is a bit harsher than mine...more of a 'Fast & Furious' sound....
His strut braces do make a difference on cornering, though. Feels like sports springs. Are Probe springs stiffer than ours? Feels that way...
Thanks again, Grendal! u2, Dave!
Old 9-17-03, 5:48   #11 (permalink)
  Total: 26 Power: 5
cruisemad's Avatar
Hmmmm J-Spec engine!!! Was he running all the J-Spec ECU and Ignition to go with it or not???
As for exhaust Diameter. I read ages ago (nearly 18 months ago now) that a 2.5" Diameter exhaust did reduce back pressure on our cars and should only be used on Forced Induction applications. To increase power and torque on a totally standard car to get a 2" System. Standard is 2.25"
I will probably need to get my leads mad up as ive got 7 cause im running the J-Spec Coil and Dizzy!!!
Kyle
AKA CLUTCHMEISTER
Old 9-17-03, 8:06   #12 (permalink)
  Total: 27 Power: 5
Yes, I'm quite sure he was running the other ECU. He was deff running the other ignition.
Old 9-17-03, 8:23   #13 (permalink)
  Total: 26 Power: 5
cruisemad's Avatar
That suprises me. Most ppl use the standard KL03 Dizzy because the wiring setup is different. It doesnt actually give any real gains apart from they dont have the dizzy fault like the uk car.
If he has the ECU and Vaf he is quite lucky. Most ppl just get the engine and run it on the UK ecu. Any chance you can do me a favour and email him and ask what he has done about the speed limiter.
Kyle
AKA CLUTCHMEISTER
Old 9-17-03, 9:22   #14 (permalink)
  Total: 27 Power: 5
Here's his reply:
still running the UK ECU till the Corksport one arrives from the states mate. so it wasnt an issue. The biggest pain was the EGR
U can catch him on FPOC, where he's a mod.
Old 9-17-03, 9:32   #15 (permalink)
  Total: 26 Power: 5
cruisemad's Avatar
Sounds like he is using all standard UK ignition as well then. Its what most ppl do. The only thing is the 200bhp engine becomes about 190 and why bother fitting the EGR Valve!!! It only slows you down even more!!! I got through emmsions tests without one and ive known standard J-Specs to get through the emisions tests without them aswell.
AKA CLUTCHMEISTER
