Old 5-8-04, 17:14   #1 (permalink)
MX6.com Supporter - Click Here for Information Ex-Mod
  Total: 225 Power: 5
kenholland's Avatar
The engine swap thread...
Hi all,
I've been looking through Haynes and other sources and have come up with a check list of things I need for the engine change. Feel free to add any suggestions of ones I've missed:
Engine oil & filter
Cam and drive belts
Gearbox oil
Manifold gasket sets (I may as well keep the shiny covers?)
Water pump
Coolant
High temp grease
Plenty of old blankets and rags
Plastic bags for bits
Sticky labels to mark up connections, hoses etc before removal.
Digicam to take plenty of snaps of what it should look like.
Laptop to see what it should look like when we're putting it back together
Possibly new clutch plates (can I get an uprated one in time?)
Possibly MX3 flywheel
Apparently, the aircon will need refilling after the swap as we have to remove the compressor or pipes, so I better look for someone who can do that locally too.
Oh, and plenty of beer indoors for the evenings...
Ken
Old 5-8-04, 17:48   #2 (permalink)
  Total: 54 Power: 5
xedos 6's Avatar
First and foremost Positive thinking ken
axle stands better bolt access with wheels off
Engine hoist check lump weight ? height in book before getting plus chain not washing line klye with a hoist hmmmmmmm
BIG hammer soft faced + wd40 lots
beg borrow steal good selection of spanners, sockets ect ther more the merrier
Swafega its dirty down there
access to transport for that vital thing missing on the day... bus does not count
Not forgeting sunshine on the day if outside
more
club film possibly to sell of course
Roland
Why mod when you drive Perfection
UK Engine Swap Team Member if you can find us - you can hire us
xedos 6 is offline   Reply With Quote
Old 5-8-04, 17:51   #3 (permalink)
  Total: 457 Power: 5
Einstein's Avatar
Right... here's what the bible says... in brief..
  1. Release fuel pressure
  2. drain engine and gearbox oil
  3. jack up front of car
  4. remove front wheels
  5. plastic covers underneath and sides
  6. fresh air duct
  7. air filterbox
  8. battery and carrier
  9. accelerator cable
  10. radiator hoses
  11. cooling fan connectors
  12. radiator and fans
  13. drive belts
  14. p/s pump (don't remove hoses) no need to bleed or top up
  15. a/c compressor (don't remove hoses) no need to recharge, save £££'s
  16. cruise control actuator
  17. Electrical connectors
  18. fuel and heater hoses
  19. clutch release cylinder
  20. transverse crossmember
  21. exhaust pipe
  22. shift control rod (gearbox)
  23. extension bar (gearbox)
  24. tie rod ends (balljoints)
  25. bottom ball joints
  26. driveshafts
  27. engine mounts
  28. engine mount member
  29. finally, engine and gearbox up
Pictures are available, but not really in great detail... and Kyle will breeze this anyway.
John
"Lexarse" GS 300
Still got zoom zoom zoom!
Einstein is online now   Reply With Quote
Old 5-8-04, 18:41   #4 (permalink)
  Total: 30 Power: 0
Chastiser's Avatar
dont forget the plasters and swearbox(grin) - good luck.
Mike
Chastiser is offline   Reply With Quote
Old 5-8-04, 19:15   #5 (permalink)
  Total: 54 Power: 5
xedos 6's Avatar
OK here's some more defo's
Trolley jack
Timing light
Ball joint splitter
Thrust bearing kit if replacing clutch poss clutch mandrel
All fluids including more
Mole grips
Access to vice
Not essential but handy to have about ..be prepared motto comes into play
Tap & die set or thread cleaner rod
Circlip pliers external & internal
degreaser
Loctite
Pry bar
Multi meter
Selection of nuts bolts washers on hand ( metric)
Cable ties / electrical crimp / connectors
solder gun if required
Will post more if old brain allows
John your engine list...it won,t come out with the earthing strap connected
roland
Old 5-8-04, 21:33   #6 (permalink)
  Total: 30 Power: 0
Chastiser's Avatar
Access to vice
i wouldnt have thought that ken would have had access to the internet while changing the engine(grin).
Mike
Old 5-9-04, 4:52   #7 (permalink)
  Total: 457 Power: 5
Einstein's Avatar
And I think no 17 will cover the earthing strap (sort of)
John
"Lexarse" GS 300
Old 5-9-04, 6:06   #8 (permalink)
  Total: 17 Power: 5
ken looks like everyone has thought of most things, but if you need anything out towards my area yeovil just let me know and i'll help get what ever ,,,,good luck mate adrian
pro-kart is offline   Reply With Quote
Old 5-9-04, 6:09   #9 (permalink)
  Total: 26 Power: 5
cruisemad's Avatar
never looked at it like that.
Ive done it that many times now i dont mark up connections cause all electrics only fit one way anyway!!! As for coolant you only need to disconnect 4 hoses.
The way i normally do it is to take both cross members off and get everything off underneath first including drive shafts and then get to work on top. As ive said my record for one out (with a buzz gun) is about 1 hour 30min on me todd!!! Without and just my trusty ratchet for company its nearer 3-4.
You dont need power steering fluid as its easier to leave the pump on the car. Trust me on that one.
MEMBER OF THE YEAR 2005
AKA CLUTCHMEISTER
Old 5-9-04, 6:20   #10 (permalink)
  Total: 26 Power: 5
cruisemad's Avatar
ken if you can get an mx3 flywheel now is the time. Speak to mazdaspares as they are always breaking engines and saved me when i needed 1 yes 1 ze cam and my flywheel.
As for clutch its a good idea but you wont get an uprated on in time. If its ok leave it for now and get an uprated one later.
Kyle
AKA CLUTCHMEISTER
Old 5-9-04, 6:54   #11 (permalink)
  Total: 47 Power: 5
u going live via web cam for this engine swap ken? lol
http://www.cardomain.com/id/wolf_funk
MODS: Racex Performance Chrome Filter, mazdaspeed sunvisor, . tinted back lights, leather seats duel fog light. . rear facing camera. . Have TOYO Proxies fitted. NOW HAVE EAGLE TALON CAI STAINLESS STEEL CATBACK TINTED WINDOWS
wolf_funk is offline   Reply With Quote
Old 5-9-04, 6:55   #12 (permalink)
  Total: 47 Power: 5
have u got a sky hook for this one?
Old 5-9-04, 7:02   #13 (permalink)
  Total: 457 Power: 5
Einstein's Avatar
Can't do a live transmission on this.. no way....
Just think what would happen if Roland got hold of it.. &^*%*
"The party before Japfest 2, (the nightmare begins)"
John
"Lexarse" GS 300
Old 5-9-04, 10:50   #14 (permalink)
  Total: 225 Power: 5
kenholland's Avatar
LOL all.
Been busy today - here's where I'm up to:
Car jacked, chocked and on axle stands.
Fuel pressure relieved (the squirty way when I removed the FSE)
CAI etc all removed back to the TB.
Battery and tray out.
Engine drained (it was mostly coolant). Gearbox still to do.
Splash guards off from underneath.
Coolant drained (what there was!)
Hoses off, rad out, fans out (in that order 'cos the aircon pipe is in the way)
Fuel and heater hoses off.
Accelerator cable off.
Wiring nearly all off with plenty of photos as I went and sticky labels on lots of connectors. I'm stuck on one small spade connector rear bottom left which I just can't get off at the moment...
Swear box full, plasters all used up.
I've left the wheels on for now 'cos I don't want some pikey nicking my discs.
Dunno how the heck Cruise managed an hour and a half - it's taken from 10am to 3pm for me to get this far!
I'm checking on a couple of engine warranties, what's included etc tommorrow and all being well will order then - should be delivered this week. I'll also get hold of MazdaSpares to see if they have a flywheel. And Magna Mazda to order up belts, gaskets, oil filter etc.
Right now it's time for a long soak to ease me old bones.
Cheers,
Ken
(I'm surprised I haven't had a PM from Roland asking for the address so he can come and film the lift. )
Ken
Old 5-9-04, 11:21   #15 (permalink)
  Total: 86 Power: 5
torque wrench
You will need one of these to do up new bolts to the required torque. I have a Halfords Professional job which will pull up to 200 NM.
For getting nuts and bolts undone which are determined otherwise a breaker bar (the biggest you can get your hands on and 1/2" drive) and a plumbers / Stillson wrench. These will work even on fasteners which are really rounded off.
At some point you will need to support the weight on the engine on a jack placed under the oil pan so make sure you have a spare jack and a big lump of wood to spread the weight on the pan. I know it sounds trivial but not everyone has wood lying about.
I have all of these so if you need a hand let us know.
regards,
Ian Chequer
Forgiven - maybe
Forgotten - not likely
