Averyone here must be aware of the very distinctive exhaust note on a Scooby. Sort of a "missed beat" type noise due to the deliberate missmatched exhaust header lengths built-in to the design.
Well, since I've had the KLZE fitted I've noticed much the same sort of effect with my MX6! Not only has the exhaust note deepened quite a bit, it definitely warbles on acceleration...
When we fitted the new engine we had to replace the J-Spec rear exhaust manifold because 2 of the studs had sheared off. We used the UK one and Kyle manufactured a plug for it to block up the EGR port. (He actually welded a plug into the end of an EGR screw.)
I suppose that, in some small way, the difference is just enough to put the exhaust "out of phase" and produce the Scooby effect...
The Subaru engine is a flat four and each pair of pistons fires at the same time so they "punch" into the crankshaft together.
So you get half the number of exhaust pulses per revolution of the crankshaft as with a straight four engine, and a very uneven exhaust note.
Careful planning of the exhaust manifold can allow existing exhaust pulses to "help" each other and aid exhaust flow and this might result in odd warbling effects.
regards,
Ian Chequer
Forgiven - maybe
Forgotten - not likely
Sounds like a new breed of 6 to me...
The all new "Scooby 6"
Glad you like the sound though... I just hope it isn't as loud as most Scooby's.
One of my mates has a Scooby with the rediculously large zorst on the back...
Lets just say he don't use the radio.
