Go Back   MX6.com > Regional Forums > Canada > Western Canada
Old 5-27-08, 21:24   #1 (permalink)
  Total: 11 Power: 1
Exclamation Final Questions
Okay, the KLZE swap is planned to happen in the next week or so and I have a few final questions. My car is a 1996 V6 5 speed. First of all, from all that I've read the ZE is a direct swap, but to get your last 8-10hp you need to get either a JDM ECU or get yours chipped. So if I just swap out engines will everything work fine? Also I have read that the Japenese motors were only available with a 4 speed auto so is my 5 speed manual a direct bolt up to the ZE? That's really all I need to know other than the ODB I or II MAF. Does it need to be changed or what is the deal there.
Any help would be greatly appreciated.
Thanks
-G
1996 Mazda MX6 - ZE Swap
http://www.cardomain.com/ride/2979380
-Grant
GrantzSiX is offline   Reply With Quote
Old 5-28-08, 0:32   #2 (permalink)
  Total: 154 Power: 3
yes will work with your stock ECU
yes will bolt up to 5spd MTX
use stock VAF with stock/chipped ECU, JE50 VAF with J-Spec ECU
Mods: KLZE, I/H/E, Hi-Flow Cat, Stainless clutch line, Engine mount inserts, ACT HDSS clutch, MX-3 flywheel, Chipped ECU, J-Specs w/HID, K-Sport coilovers, RSTB, FSTB, Addco RSB, Clear side markers
Not installed yet: HEI module
