Help a car nut stranded in Japan - Mazda MX6 Forums: MX6 Forum
Go Back   Mazda MX6 Forums: MX6 Forum > Regional Forums > Australia & New Zealand > A and Z Lounge
Register Home Forum Active Topics Garage Garage Photo Gallery Arcade Mark Forums Read
Old 10-22-05, 10:56   #1 (permalink)
Need to know if there are any repair manuals in Australia for the MS-8. Want to pick one up for my vehicle, but don't a big fan of Japanese repair manuals, because I can't read them. Found out that Australia had the MS-8, and was wondering what they run over there.
ocshaman is offline   Reply With Quote
Old 10-22-05, 17:35   #2 (permalink)
  Total: 178 Power: 5
tx5turbo's Avatar
I have never heard of a MS-8, do you know any other names of it?
R32 GTS-t Type M Coupe - RB25DET
R32 GTS-t Type M 4 Door Track/Drift Whore
R31 S3 GXE - The Daily - Gotta love box!
tx5turbo is offline   Reply With Quote
Old 10-22-05, 18:11   #3 (permalink)
  Total: 286 Power: 5
What's an MS-8?
Is that a Mazdaspeed RX8?
1993 Mazda MX6 4WS
2004 Mazda RX8 Luxury
"If it was so, it might be; and it were so, it would be; but as it isn't, it ain't. That's logic." - Lewis Carrol
Cromax is offline   Reply With Quote
Old 10-22-05, 19:37   #4 (permalink)
yeah
May also be called the efini MS-8. A few A.NZ guys were talking about them here
Since I can't post links, do a search for ms-8 in the gallery section
and they look like this
go to www dot jaon-long dot com/car/front.jpg
Old 10-22-05, 20:31   #5 (permalink)
RdS
  Total: 513 Power: 5
This is an efini MS-8 it is a sedan. kinda reminds me of a eunos 500 or 800. might run the same mechanicals?
Red GE's FTW. GE20L200102537 ?? :'(
RdS is offline   Reply With Quote
Old 10-24-05, 4:14   #6 (permalink)
  Total: 276 Power: 5
ODIN's Avatar
The MS-8 might of been in NZ, but not in Australia, if anything it looks a lot like a mazda 929, so maybe they share a fair few components or it's a j-spec reskin.
Sold: 93 MX6 4WS
Current Car: R32 Skyline GTS4 Sedan
ODIN is offline   Reply With Quote
Old 10-24-05, 4:46   #7 (permalink)
  Total: 90 Power: 5
similar to the 929, but slightly different...engine may be the same..
I havent heard of MS-8 at all....neither seen that car...figure out what engine it is and then it will be easy to look for the manual...and thats the engine side of it only...
Traded With: TX5F2T - PSI626 - GotF2TinGD - CardinalBiggles - ausloki - boki82 - Capri72 - Zorb_Rules - nehpets - 000mx6 - tren - rodhog - jesiotrot - NiN^_^NiN - racka
91gd626turbo is offline   Reply With Quote
Old 10-24-05, 4:48   #8 (permalink)
  Total: 90 Power: 5
NZ model indeed...check this out...
http://www.loot.co.nz/Main/ListDispl...FINITY=1392182
Old 10-24-05, 4:50   #9 (permalink)
  Total: 90 Power: 5
MAZDA Efini MS-8
http://arthistoryclub.com/art_history/Efini_MS-8
http://fact-archive.com/encyclopedia/Efini_MS-8
The Efini MS-8 was a luxury car produced by Mazda and sold through the Efinimarque from March 1992 through 1995. The car is a replacement to the Mazda Persona and Eunos 300 on the Mazda M platform.
Just like the Persona is based on the 1987-1991 Mazda Capella, the MS-8 is based on the 1991-1997 Mazda Cronos. The MS-8 is a hardtop-style, stylish sedan in the vein of the Toyota Carina ED . Unlike the ED or the Persona, however, the MS-8's body has a B-pillar that is much thicker below the beltline than it is above. Doing so allows the bodyshell more rigidity while still maintaining an airy cabin. Such a B-pillar means that the front seatbelts must be installed below the belt line. It appears through the lining of the rear door, and is routed through a guide built into the front headrests.
The MS-8's interior design has several unique features. The car is only fitted with a 4-automatic gearbox, and the gear shifter is mounted on the dashboard next to the air-conditioning controls. Doing so eliminates the floor console between the front seats. The display for climate control and factory-equipped audio is located atop the dashboard, in a thin slit right before the windshield defroster. The sunroof is very large for its day, extending all the way above the rear seat footwell.
Following the 1991 Efini RX-7, the MS-8 is also available with the Bose Acoustic Wave Guide audio system, a compact subwoofer design that utilizes Bose's proprietary know-how.
four-wheel steering is an extra-cost option. Like the system on the Mazda Sentia, it is designed to minimize turn radius at town speeds, and improve stability at highway speed.
Production for the MS-8 ceased when Mazda's multi-brand strategy failed in Japan, and the company suffered financial difficulties.
Engines: KF
  • 2.0 L KF - 1995 cc (78x69.6 mm) - The 2.0 L KF-ZE engine produced 159 hp (119 kW) and 132 ft.lbf (180 Nm).
Applications: KL
The 2.5 L (2497 cc) KL family uses an 84.5 mm bore and 74.2 mm stroke. It includes the Japan-only KL-ZE, which produced 199 hp (149 kW) and 165 ft.lbf (224 Nm). Another variant, the KLD (sometimes called the KL03) was the worldwide version, with 164-170 hp in various applications. A Variable Resonance Induction System (VRIS) was used on all variants, optimizing torque production over the entire rev band.
Applications:
1997 1996 1995
1994 1992
Old 10-24-05, 5:04   #10 (permalink)
  Total: 23 Power: 5
it looks simular to the 929 except 929 has a 3litre v6
toyriders is offline   Reply With Quote
Old 10-24-05, 5:08   #11 (permalink)
  Total: 90 Power: 5
yeah..cause its only comes in 2.0l and 2.5l...but indeed its very similar..
Old 10-24-05, 18:22   #12 (permalink)
Friend has an 929, similar, but smaller. That's the car. So NZ has it but not Australia, hmmm... and NZ'ers help me out?
Old 10-24-05, 19:05   #13 (permalink)
  Total: 286 Power: 5
From what I recall, it's harder to bring a car in from NZ than it is from Japan.
1993 Mazda MX6 4WS
Old 10-24-05, 22:22   #14 (permalink)
  Total: 90 Power: 5
well here is the rules for that. I was gonna import this FE3 1st gen nice with body kit but the drama is:
you must own the car for at least 12 months to be able to import it into australia from NZ.
I called the customes and they said if you've owened the car for a yaer then you are allowed to bring it to australia.
well shipping and all taxes and fees were around $3000 and the car was sold around $2200 AUD....but I couldnt import it...
Those Jap importers thats what they do...they buy the car there and they have it for a while or something and then they bring it back, or for those MASS IMPORTERS there might be a different law but yeah thats why I couldnt import that car....
for more info call The "Australian Customs" for import policies.
Old 10-26-05, 7:15   #15 (permalink)
What about the manual?
Powered by vBulletin®. Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
